Have a new battery from Advanced Auto. Does not appear to have a vent tube hole but has a hole on the end of battery. Battery is sealed. Should I connect to this not?
test point
close
- Join DateMar 2008
- LocationEllijay
Liked:1,116 Times in 935 Posts
All three of the AAP batteries listed as direct fit for the Jaguar specify that they are vented. Mine had a hole at the top center of the positive end of the battery for connection of the vent tube.
The non-original battery that came with my car was not vented. When I replaced it I made sure the new one had vent holes at both ends with tubing and plug for the end not used.
Then I could not find anywhere in the floor of the trunk (boot) for the vent to go, no factory penetration whatsoever, so mine is unvented and has been for 3+ years with no apparent ill effects.
Vector
Vector
Vector
There is no way that you car came from the factory without a vented battery and a hole for the vent tube to go through.Originally Posted by Vector
The non-original battery that came with my car was not vented. When I replaced it I made sure the new one had vent holes at both ends with tubing and plug for the end not used.Then I could not find anywhere in the floor of the trunk (boot) for the vent to go, no factory penetration whatsoever, so mine is unvented and has been for 3+ years with no apparent ill effects.
Vector
The hole is toward the positive side of the battery next to the wiring harness.
Its not on the bottom of the trunk
Thanks for the info, I'll take a look and see if it is in the location you described.Originally Posted by luc
There is no way that you car came from the factory without a vented battery and a hole for the vent tube to go through.The hole is toward the positive side of the battery next to the wiring harness.
Vector
motorcarman
close
- Join DateDec 2009
- LocationWise County,TX
Liked:9,640 Times in 5,765 Posts
ALL X308s have the same vent tube outlet in the boot.
Someone might have 'repaired' the hole at sometime in the past.
bob gauff
bob gauff
rocklandjag
close
- Join DateNov 2009
- LocationNew York state
Liked:220 Times in 158 Posts
Quote:
Here ya go, at least it is on my '98 model.
retro
retro
I just bought this type of battery. The small circle on the positive terminal is a plug to cover the side of the battery that you do not connect the hose to. This battery has a vent hole on each side in the middle of the plastic cover.
The plug snaps off the cover and fits in the un-used end.
The battery was $135 so not cheap but I would not install a non-vented battery in the trunk of any car
Quote:
Ah, OK ..... I gotcha!Originally Posted by rocklandjag
...The plug snaps off the cover and fits in the un-used end.....
I wasn't astute enough to realize that was a plug 'til you pointed it out, but I was smart enough to plug the unused hole by other means.
Thanks,
retro
