Best fuel pump?!!?
Old May 29, 2013 | 05:12 PM
coastaljag98's Avatar
Default Best fuel pump?!!?
Stranded again. Pump is 6 months old from eBay Bosch. I am pissed. Flipped relays so I know it's pump.
Old May 29, 2013 | 11:01 PM
Bump....c'mon. Not the only one!!?
Old May 30, 2013 | 07:04 PM
C'mon y'all. I need to know before I order another crap pump. Is denso good or Bosch or what.
Old May 30, 2013 | 07:11 PM
danielsand's Avatar
I would go Denso, and I would order from "the usual suspects", not Ebay.
Old May 30, 2013 | 07:25 PM
Cool. I am going to pull it apart. The pump runs but I'm going to cut a hole in the rear deck shelf and see if maybe the hose came off the pump. I'm getting no fuel pressure but pump runs. Strange.
Old May 30, 2013 | 07:28 PM
danielsand's Avatar
Who installed it? Something came undone. You don't need another pump.
Old May 30, 2013 | 10:06 PM
Well my dad and I did it. So we are gonna cut out the rear deck and see.
Old May 31, 2013 | 10:11 AM
danielsand's Avatar
That's the best way to do it. When the time comes, I will do it the same way. I will have another person with a spray bottle and water ready. Back seat comes completely out, rags on the bottom to soak up the water, one person on the Dremel, and one spraying. No sparks. Just in case. Once the "trap door" is cut out, I will make a "lid" for the hole, and when the pump is done, I'll bolt the lid on with self drilling sheetmetal screws. IMO, there will be no structural weakening of the body at all. The hole has to be big enough to get in with the tools, and not as big as it shows in some pictures. The best part? No gas in your face, no hoses to deal with, and the fuel pump replacement whenever you please.
Old May 31, 2013 | 05:32 PM
We took a chisel and hammer and made ours. The hose had come loose off the pump and now she runs fine!!
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
