best way to clean engine
Old Apr 11, 2008 | 02:53 PM
slanteyedmonkey's Avatar
Default best way to clean engine
i've been maintaining the car but wanted to clean the engine and compartment. i think the best thing to do would be to do it when the engine is cold. any suggestions so i dont screw something up?
Old Apr 11, 2008 | 04:50 PM
JagtechOhio's Avatar
Default RE: best way to clean engine
Hi Monkey,
This discussion came up a couple of weeks ago, but I'll give you the brief version of my answer:
The first and only XJ8 engine I washed lost both of the knock sensors immediately. Not water or corrosion in the connectors, not water or corrosion between the sensors and the mounting studs or bosses on the block. Two bad knock sensors.
Old Apr 11, 2008 | 06:04 PM
jag_genius's Avatar
have it running when cleaning it.. and dont put too much water pressure..
FactoryJaguarTech's Avatar
Lol Jto.
I was the inside of the engine bay with some degreaser and pressure hose. Just dont do the engine that way.
Use a damp cloth and wipe it down. Use a spray degreaser if you need for the toughest spots.
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
user 652867429824
Sep 5, 2015 12:53 PM
bdboyle
Sep 4, 2015 06:16 AM
OkieTim
Sep 2, 2015 12:48 PM
