Bit of Help
Old Mar 20, 2013 | 03:23 AM
Yala's Avatar
Default Bit of Help
Ok so its the 3rd week after buying the car. I find that there is a petrol leak, called in the mechanic and he says that 3 injectors need replacing as the previous owner or mechanic has tampered with it and damaged them even though only one is leaking 2 others are damaged as well so replacing them will be ideal.
Also i know my car came with the auto dimming rear view mirror which needs replacing as it just loosely hangs and the only thing i can see are the passengers at the back. Now i think my car comes with the Auto headlight option since i can see the auto mark on the light shaft which doesnt function when i turn it on and im not sure about the rain sensing wipers option either.
so my question to you folks is
1) Could you guys help me with the part number for injectors, cost of new or used and where i can source it in england
2) Part number of the rear view mirror
3) How do i go about checking if the rain sensing wiper option was available.
Any help on these will be greatly appreciated im trying to get the car back into nick shape as much as possible its an obsession owning a Jag and it keeps growing on me everyday
Old Mar 20, 2013 | 06:08 AM
Originally Posted by YALA
................. my question to you folks is
3) How do i go about checking if the rain sensing wiper option was available. .........
Here is the Injector Part Numbers for the 3.2 Litre:
Here are the Rear View Mirror options:
If you have Rain Sensing Wipers fitted, there will be an AUTO position on the rotary collar. Set the rotary collar to AUTO and the stalk to INTERMITTENT wipe to use the function.
You are looking for new or used parts suppliers in England?
Old Mar 20, 2013 | 11:38 PM
Yala's Avatar
Thanks graham this will really help me out. Yup in england its half the price over there and i have family and friends who travel back and forth so its a matter of carrying stuff with them unless of course its a big item which needs to be shipped. I remember the auto mark on the light shaft but dont remember auto on the wipe shaft ill check on it. Cheers for the help
Old Mar 21, 2013 | 01:05 PM
SuperSport's Avatar
I believe the Auto Wiper also has a sensor built into the Rear View Mirror in the mounting bracket.
Old Mar 23, 2013 | 07:21 PM
Lear45's Avatar
Ebay has everything. Use Ebay UK to save on shipping. The mirror should just need an
adjustment. Mine used to fall off, but I got it to stay without replacing it.
Old Mar 25, 2013 | 03:42 AM
Yala's Avatar
i got in touch with a breaker company over the weekend they asked me if the injectors were bolt on on clip on types i was thinking once the part number is given it should be easy but never knew there can be more than one variant with the same part number..Lear45 thanks i get it shipped to a UK address and get some one to hand carry it over...the mirror is loose where the mount ball attaches it self to mirror bracket
Old Apr 22, 2013 | 04:18 AM
Yala's Avatar
Update
1) Up and about running the car after the injectors were fixed. Thought id give it a go and try and get the FOB working together with the alarm. I replaced the batteries on the FOB and no go with that, so next i thought ill run through the fuses but the diagrams dont point out to the security system, except for security sounder. Anyone know which fuse/es to check and what my next step would need to be and is there anyway i can check arm the alarm from the master key?
2) next on my list of things to do is to get the boot unlocking mechanism working. when i press the button i can hear a motor running but no popping trunks. i can open it with the master key so im wondering why it wont with the motor as its the same mechanism.
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
Samheath100
Sep 24, 2015 08:42 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
sonofdave1980
Sep 14, 2015 07:45 PM
