Black Box in Fuel tank? What is it?
Old Jun 10, 2012 | 11:40 PM
RCoombes's Avatar
Default Black Box in Fuel tank? What is it?
I have a 2003 XJ8, with a burned fuel pump. In fact, the 2-pin connector is also burned. I have a replacement pump, but noticed a black box, in-line with the fuel pimp wires (in the tank), and I don't know what it is. I suspect that it's electrical noise filtering, but should find out for sure. I don't want to change just the pump if this is also bad. Does anybody know what this part does? Picture attached.
Old Jun 10, 2012 | 11:56 PM
plums's Avatar
Noise filter. There was a post about it some time ago.
Old Jun 11, 2012 | 12:24 AM
RCoombes's Avatar
I did a search for "fuel pump" & "noise filter", and couldn't find it. Am I correct in assuming that it's just a ferrite bead around the wires? If so, I can just check for continuity, as ferrites usually don't burn.
Old Jun 11, 2012 | 08:37 PM
QuadManiac's Avatar
It's most likely something like a T or a Pi filter - a pair of inductors surrounding a cap to ground or a pair capacitors to ground with an inductor in-between or equivalent. See picture.
Attached Thumbnails Black Box in Fuel tank? What is it?-lc-lowpassfilters.jpg
Old Jun 11, 2012 | 11:37 PM
plums's Avatar
You can look at the patent filed by the manufacturer, Walbro.
Denso has a patent on in-pump electrical noise filtering, so no doubt Walbro had to go external.
A ferrite bead would do just as well on the external wiring leading up to the tank if you want to just bypass the "black box". Those link leads are expensive, and prone to failure at the connectors.
They must have some effect on power handling because it is *always* the ground side connectors that burn up.
Mine are simply deleted without any ferrite bead or any other noise reduction devices and the sound system works just fine ... the rare times that it is in use.
Old Jun 12, 2012 | 08:58 AM
RCoombes's Avatar
We decided to replace the link lead, as the wire was burned so badly, we couldn't get solder to stick. Maybe I'll get to drive it today!Thanks for all the help! Bob
dsnyder586
Dec 29, 2024 07:39 PM
tomsjag
Jun 10, 2023 10:02 AM
hen555
Sep 7, 2015 11:13 PM
alpecsa
Sep 7, 2015 11:55 AM
deanh
Sep 6, 2015 08:20 PM
