Both cars have ABS light, trac and asc not available...
Old Nov 15, 2013 | 03:32 PM
princemarko's Avatar
Default Both cars have ABS light, trac and asc not available...
First the super V8... I know I need brakes/rotors.... Could that be the culprit? It comes on sporadically.
The XJR Has he same problem but stays on now continuously.
No codes on either
Old Nov 15, 2013 | 03:37 PM
flay's Avatar
I had a broken ABS cable with these messages and later when the throttle body was broken. No connection with discs and pads.
TC at start up is weak battery (I see it every weekend when I take it out of garage).
Old Nov 15, 2013 | 03:50 PM
RJ237's Avatar
princemarko, you say no codes. If you are using a generic reader you will not be able to display C codes. The usual culprits are dirty sensors, broken cables, and failed solder connections to the abs pump. Here is a trouble shooting guide:
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Please note that the resistance of the sensors is typically 1000- 1040 ohm, not 2000.
Last edited by RJ237; Nov 15, 2013 at 03:53 PM. Reason: forgot resistance correction
Old Nov 15, 2013 | 07:54 PM
mikebaker3's Avatar
Default ABS Light
Disconnect the negative battery post.
Go to the ABS motor behind the left headlights. Disconnect the square connector and clean both sides, motor and connector with contact cleaner.
There is a ground stud with several eyelets secured with an acorn nut. remove the nut and clean all eyelets with contact cleaner.
Many of the circuits on these cars are sensitive to high resistance from corrosion on contacts.
Old Nov 15, 2013 | 08:07 PM
guyslp's Avatar
Also, if you're going to the trouble to do what mikebaker3 suggests, make sure to either coat the connections with electrically conductive grease (e.g., Sanchem's No-Ox-Id A-Special, Volt, or others) to prevent corrosion from occurring again. If all you can get your hands on in short order is dielectric grease, connect everything up tight then apply it over the exterior of the connection.
These cars suffer from myriad "ghosts in the machine" secondary to simple electrical issues. Doing whatever you can to avoid having to revisit any connections you have already visited just makes good sense.
Old Nov 16, 2013 | 04:07 PM
the Super V8 I'm sure is a dirty sensor since brake dust is flying out of it right now...
The XJR.... that has the abs and other warnings coming off after start and as long as i feather the brakes its ok... but if i slam on the brakes, the seem to depress and the lights come on
Old Nov 23, 2013 | 10:16 AM
jaguar jon02's Avatar
mines been on for almost 2 yrs now . don't have time to fix own car
Old Nov 23, 2013 | 06:33 PM
Sean B's Avatar
@marco - the R sounds like pump solder points failing. There's plenty of posts on how to fix it.
Jimscriv
Nov 4, 2015 02:18 PM
gene1
Sep 3, 2015 08:04 PM
roumor
Aug 28, 2015 01:02 PM
Terencex
Aug 26, 2015 08:47 AM
NinoGrimace
Aug 26, 2015 05:15 AM
