Broken left mirror
Old Mar 31, 2014 | 04:15 PM
smtguy's Avatar
Cool Broken left mirror
My XJR was parked on the street and I came out to go to work this morning and some richard cranium managed to hit and break my left mirror housing (no note left of course). It snapped right where it pivots to fold in (manually).
Questions:
Is this part of the mirror assembly repairable, or do I need to replace the whole assembly?
If it is repairable, does anyone have an exploded view of it?
If I go for a used one do any of you have one available for sale?
Specifics: Heated, Power, Memory, Color: MDX (Platinum). The actual mirror didn't break, just the part where it rotates to fold in.
Thanks in advance for the help guys!
Old Mar 31, 2014 | 06:09 PM
Sean B's Avatar
I'd suggest a replacement as they're cast alloy and as strong as peanut toffee.
might have an MDX cover in the spares shed...
It's one torx bolt behind the black plastic cover at the front base of the widow frame inside, it's possible to remove the cover with a bit of wiggling then also wiggle the wiring harness up to the clip and unplug.
I have the window down and hold the mirror while unbolting to save a dent.
Power and heated is standard as far as I know, only chromatic dimming and powerfold as options, I think.
Hope this helps!
Old Apr 1, 2014 | 01:00 PM
smtguy's Avatar
Hope this helps!
Thanks very much Sean. Do I need to remove the door card to be able to remove the window frame cover?
Old Apr 1, 2014 | 06:03 PM
Sean B's Avatar
by the book yes, with some plastic trim tools you don't.
Old Apr 2, 2014 | 09:35 AM
smtguy's Avatar
Thank you Sean.
Old Apr 2, 2014 | 04:18 PM
Nebraska2000ES's Avatar
same thing happened to me last fall. Bought a salvage mirror locally for $50. I'm replacing it by the end of the week hopefully. Same thing...everything with the mirror and body was fine...just the part where it folds was snapped. I have about two feet of gorilla tape holding it on for now.
Old Apr 2, 2014 | 04:20 PM
...my assailant left a note though. Old neighbor so I saved them the $900 insurance bill and went cheap.
Old Apr 3, 2014 | 12:04 AM
smtguy's Avatar
Honesty is the best policy, but you don't get much of that around these parts!
Old Apr 6, 2014 | 12:16 AM
fmfz12007's Avatar
Spotted a x300 VP in the salvage yard today. It's a 96, mine a 95. I'm sure they are the same. I have one question. Do all x300 xj6's have heated mirrors. Mine is not a VP. Not sure that it does. Is always garaged so I've never had the need for them to be. The wiring is my concern. Don't know what I think of the chrome on the 96. My car suffered the same damage as yours. Anyone know? Epoxied it back together six months ago and still good. I just don't like rigging it. Thanks
Old Apr 6, 2014 | 09:49 AM
smtguy's Avatar
Don't know about the '95 or '96s. Probably your owners manual will tell you about your car at least. Good luck!
Old Apr 6, 2014 | 10:20 AM
Basically, any X300/X308 mirror from 1995 to 2003 will fit any X308 but there's a number of variations in specification to be considered:
1. powerfold or non-powerfold
2. heated or non-heated
3. auto dim
4. flat or curved mirror glass
The colour of the backcover is not a problem as these are secured with round spring clips on plastic pegs and can be popped off and switched over.
St.Regis
Oct 4, 2024 12:07 PM
SCMike
Sep 22, 2015 07:34 PM
doctordeuce
Sep 12, 2015 08:30 AM
motorhead69
Sep 9, 2015 10:04 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
