Bumper painted/no more reverse beep alert
Old Sep 1, 2019 | 07:24 PM
3timejag's Avatar
Default Bumper painted/no more reverse beep alert
I recently had to have my bumper repaired and repainted. They did a fantastic job with the exception that now, when I put the car in reverse...I’m getting a solid beep that lasts 10 seconds, and nothing else. It seems the alert system is disabled.
My though is that they painted over the sensors? I’m not sure where they are, but I’m thinking they are the little nodules, one on each side and two on the rear part.
My question is...can I use something to remove the paint on the sensors, or are they inexpensive enough, and easy enough to replace?
If I am wrong, and those are NOT the sensors, what could my issue be?
many thanks in advance.
Old Sep 1, 2019 | 08:30 PM
pdupler's Avatar
I'll bet the shop probably just forgot to reconnect the wires.
Old Sep 1, 2019 | 08:52 PM
King Charles's Avatar
+1 on connection.
Old Sep 2, 2019 | 07:30 AM
Highhorse's Avatar
If they did paint over them, then take it back and have them clean if off. It won't take them but a couple minutes with some paint thinner or as the previous have stated, they can hook up the connections.
Old Sep 2, 2019 | 07:54 AM
motorcarman's Avatar
If the electrical connections are good, then the paint is just too thick. We had to send cars back to the paint shop after repairs for this fault.
Highhorse 'nailed it'.
Old Sep 2, 2019 | 08:47 AM
3timejag's Avatar
Thank you to all!
Old Sep 2, 2019 | 10:26 AM
yeldogt's Avatar
My memory is the actual sensor snaps into the holder (the part that's painted) -- I don't remember having to paint the new sensor?
You can get the Ford based sensor for under $20
Old Sep 2, 2019 | 10:37 AM
Brutal's Avatar
Originally Posted by yeldogt
my memory is the actual sensor snaps into the holder (the part that's painted) -- i don't remember having to paint the new sensor?
You can get the ford based sensor for under $20
they are but a thin film. Too much and no bueno. To know if its elect or paint . Key on engine off in reverse. Put your ear right to the sensor and you should hear fast clicking if working wether paint issue or not. My bet would be they left disconnected because too much paint will render the same issue most times and a too close object. Either way they need to fix.
Old Sep 2, 2019 | 08:14 PM
pdupler's Avatar
I guessed that it was an electrical fault because on mine, if it thinks I'm too close, it doesn't just stop beeping after 10 seconds, rather it keeps going. Since he described it as a 10 second solid beep, that sounded to me like it was probably registering an error. But almost all my paintwork experience is with classic cars. So what's the best strategy dealing with these sensors? Leave the factory paint on the sensor holder and only paint the bumper cover and live with whatever match is achieved? Or is it just to strip and paint the holders separately with no primer and fewest coats that will cover?
Old Sep 3, 2019 | 02:46 PM
yeldogt's Avatar
One of mine did stop working -- the sensor is at least two parts. One of the guys in the club years back needed a new cover -- and he removed the carriers. I guess some paint the bumper with the sensors in place?
FireCrow
Sep 16, 2012 07:09 PM
99snake
Jun 18, 2012 10:32 PM
mikewv100
Jun 13, 2012 02:25 AM
Sparkers69
Apr 7, 2011 04:37 AM
stunna
Feb 21, 2010 02:31 PM
