A/C hot only & error codes
Old Jul 9, 2025 | 09:16 AM
Svalbard's Avatar
Default A/C hot only & error codes
I went and did my mandatory inspection today. Hot outside and AC on all day. Inspection went fine. On my way home I had to stop for another errand. When I got back to the car and drove away, only hot air came out from AC.
At home I retrieved the AC fault codes by holding down the AUTO and RECIRC buttons.
I get fault codes 23 and 14.
Any ideas what to do next?
Old Jul 9, 2025 | 10:20 AM
clubairth1's Avatar
Community Influencer
Need to post car details.
Year, engine, miles on car.
After that I would get a set of AC gauges on the car and post back what the hi and lo side are reading.
Old Jul 9, 2025 | 11:04 AM
Jhartz's Avatar
There is a guy outside Camp Zama who is a wiz on fixing A/C in European cars. (if he is still alive -- it was 45 years ago he fixed my Bavaria).
I would find a really good A/C shop: check the A/C switch just aft of the radiator for green foam (if that switch is blown, you will get a fault 23)
faultcode23 - Refrigerant pressure switch malfunction Harness / connector fault Switch open / short circuit. Refer to PDU23 Refrigerant pressure low refrigerant charge *Leak from damaged pipe or joint.
fault code 14 -
Water temperature input malfunction
Old Jul 9, 2025 | 02:52 PM
Svalbard's Avatar
Thank you.
FYI:
My 2000 xjr is my daily driver with 160,000 km.
eliotb
Jul 12, 2025 01:33 PM
cdma
Jun 11, 2023 12:47 PM
xk810024
Jul 10, 2021 09:16 AM
PatB
Aug 7, 2020 04:12 PM
johns55
Aug 16, 2014 03:44 PM
