cam cover vvt
Old Feb 6, 2014 | 05:31 AM
westy032001's Avatar
Default cam cover vvt
Hi all
I'm hoping you can help .
I am after a small plastic disc that sits on the top of the cam cover at the radiator end over the vvt on a 4 litre xj8 x308 , my car is a 1998 (and so has the v v t solenoid on the front of the engine ) but the car had an engine replacement in 2004 ( not sure on date ) by a jag main dealer.
That meant it was supplied with cam covers that had a hole in the top of the cam cover for the later style vvt which had the solenoid on the top of the cam cover .
It looks like Jag supplied a blanking plate which was held in with
sealant , or not in my case ! causing my engine bay to look like a BP
disaster site .
I have rang a few garages but with no luck , does anyone know where I might get one of these from,or has anybody ever seen this before ?
Old Feb 6, 2014 | 07:28 AM
JagV8's Avatar
Sounds like PCV valve. It's not a blanking cover.
Investigate more.
Old Feb 6, 2014 | 09:56 AM
Thanks for the reply , but it's just a plastic disc ( I checked the other cam cover ) , plus it's on the non pressurized side i.e between the block and front cover .
Old Feb 6, 2014 | 10:57 AM
dsnyder586's Avatar
How odd. I have not heard of that before- is it possible that they dropped in an AJ27 and used the cam covers that came with it? If I were you (and I am not) I would buy a couple of AJ26 cam covers- it will be better looking and won't leak.
Old Feb 6, 2014 | 07:09 PM
mikebaker3's Avatar
I agree with getting a pair of AJ-26 cam covers.
Old Feb 6, 2014 | 09:31 PM
motorcarman's Avatar
1997/98 XK8 or 1998 XJ8 cam covers will work.
Any 4.0 Supercharged cam covers will also work.
bob gauff
Bcrary3
Feb 21, 2023 04:29 AM
Davidvdm
Oct 7, 2015 03:18 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
jaggermang
Sep 8, 2015 07:07 PM
