can I change this hose without removing intake manifold?
Old Jun 11, 2019 | 02:15 PM
RA110623's Avatar
Banned
Default can I change this hose without removing intake manifold?
hi guys . I have vacuum leak from that hose under the intake manifold it's in the left side it's also connected to the valve cover can I change it without removing the the intake manifold?
2002 xj8
thanks.
I think it's the hose number 1 that connected to the canister
Old Jun 11, 2019 | 04:43 PM
Addicted2boost's Avatar
Short answer is yes. Before removing the old one out (assuming it’s not in 2 pieces), I tape one end of the old one to one end of the new one and just fish it on thru.
Old Jun 11, 2019 | 11:04 PM
anduha's Avatar
If the tape fails you can also use a wire coat hanger bent into a hook to pull it through. It isn't too difficult.
Old Jun 12, 2019 | 06:01 PM
RA110623's Avatar
Banned
okay , it's hose number 2 in the diagram. do you know what's the item number?
thanks
Old Jun 12, 2019 | 07:20 PM
#2 is the part load breather hose. It’s a one piece hose with 3 connections. Connects at the left hand front of the valve cover (or cam cover), travels under the intake manifold to the elbow under the throttle body and to the evaporative emissions canister purge valve.
Old Jun 13, 2019 | 04:20 AM
RA110623's Avatar
Banned
thank you . still looks difficult to change it without removing the intake manifold but I think it's possible.
found this pic . also the part number is aj84880
Old Jun 16, 2019 | 08:58 AM
SteveXJ8L's Avatar
Were you able to get the hose replaced? I just did mine yesterday. It is a pain, but really just because of the difficulty getting the connector to release from the throttle body. I ended up getting a long skinny screwdriver in there and breaking the little latching ring off the old connector, figuring I was tossing it in the trash anyway. The new hose threaded in from the front with a little coaxing to get it over and past the obstructing stuff under the manifold. The only things I needed to disconnect were the 3 electrical connections near where the T-fitting goes into the throttle body. Nothing else needs to be removed -- not even the vacuum line. Total 10-minute job.
While you have it apart, you need to clean out the fitting in the cam cover where the PLB tube attaches. If this is clogged it can cause all manner of grief with EVAP codes (ask me how I know this LOL). There was a TSB about this, that I learned about a week ago while chasing my tail with an EVAP code. Here is the web address to link to the pdf of the bulletin:
http://jagrepair.com/images/TSB/XJ/6...ings600-03.pdf
-Steve-
Old Jun 16, 2019 | 10:02 AM
RA110623's Avatar
Banned
-Steve-
I did broke the connector thats under the throttle body I tried to pull out but it was difficult and wouldn't move I used long screwdriver then while trying to get it out I broke it .
I used thin cable like hanger to pull the hose from under the manifold because the connector stuck and hit the knock sensor adjusting it here n there and pull it took about 15 minutes to install the new hose .
thanks for the link .
Old Jun 16, 2019 | 03:17 PM
SteveXJ8L's Avatar
slmskrs
40
Aug 8, 2021 07:24 PM
jimborino
Aug 18, 2019 09:59 PM
alckc
Aug 22, 2015 05:12 PM
The Coupe
Feb 27, 2012 10:43 AM
xjrwithproblems
Oct 20, 2011 11:58 PM
