Car will not shift from Park....Help!!
Old Mar 6, 2006 | 05:43 PM
Max's Avatar
Max
Default RE: Car will not shift from Park....HELP!!!!
The switch your releasing manually with the pen needs to be replaced. Go to
Roadfly
and search on "J gate removal".
Hope this helps.
Old Jul 28, 2014 | 04:44 PM
thejagman's Avatar
Default stuck in p
I had the same problem. .and member helped me...so check if the brake lights come on when u press the breaks. If they dont its the brake switch. The switch is concted the j gate solenoid...that the clunk u hear when u select from P to reverse or drive.
Old Jul 28, 2014 | 05:15 PM
deancantrell's Avatar
On my 98 I had the same thing and traced it to a blown fuse in one of the heal fuse boxes.
Old Jul 28, 2014 | 07:18 PM
jimlombardi's Avatar
I had the same problem with our 2001 XJ8 - I could not get the shifter out of park. 1st I thought that the brake light switch on the brake pedal might be the problem.
Then I also noticed that were a number of other things like the interior lights not coming on when I opened the driver's door and the garage door opener did not work. I also mentioned to my wife that there was something wrong with the windshield washers (since they were not working).
Check fuse# 7 (15 amp fuse) in the rear left hand fusebox - it controls "Body processor module (battery supply for solenoids, lamps and motors).
Sure enough it was that fuse that needed replacement and it fixed the problems.
Jim Lombardi
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
msdg137
Sep 16, 2015 06:24 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
