CD changer, ... interchangeable?
Old Apr 6, 2017 | 05:40 PM
harvest14's Avatar
Default CD changer, ... interchangeable?
Will the CD changer in my 2003 XJR parts car work in my wife's 2004 XJ8?
X308 CD changer compatible with X350?
Thanks,
Old Apr 6, 2017 | 10:00 PM
nilanium's Avatar
If I remember right the x350 uses the newer alpine fiber optic interface, so everything is redone since the x308. Otherwise, the cd changer hack aux method might be more popular on the x350's...
I'm not even sure if the CD changer swaps between HK and Alpine x308's, since the Alpine x308 amp connects to the HU thru the AINet cable, and the HK amp is a direct signal and the AINet cable just goes to the cd changer directly. That may be wrong though, it could just be the HK and Alpine amps that don't interchange. But that's all off topic...
Old Apr 6, 2017 | 10:10 PM
grandell's Avatar
I believe the change to Ai-Net was around 99/00. I believe you can swap like for like, so you can swap any Ai-Net changer, whether it was HK or not.
Not entirely sure about the pre-Ai-Net ones though, as I've only really studied the 2001 wiring diagrams
Old Nov 13, 2021 | 11:46 AM
FelixArthur's Avatar
Hi I have just escaped from the x350 section where I have been lurking for many years.
I have CD player with CD changer in the boot.
The vehicle is 17.5 years old
Plays a CD for 40 secs then stops-no sound
Every CD position the same.
I think maybe new motor needed but what do you people think?
scrappydoo
Audio/Visual Electronics
17
May 3, 2021 07:55 AM
tilbury
Aug 16, 2012 08:51 AM
SuddenSam
Aug 6, 2012 10:15 PM
rcoole
May 16, 2008 07:21 PM
