A chance to win 20 bucks
Old May 12, 2008 | 05:28 PM
Rock Meathammer's Avatar
Default A chance to win 20 bucks
Check out my transmission thread, guess the problem that I found, I instantly paypal you $20. Factory techs welcome too. Guess as many times as you want. I am very honest and will definately tell you if you're correct. Good luck and have fun.
Old May 12, 2008 | 06:15 PM
Default RE: A chance to win 20 bucks
Dude! $20! No losing! Only winning! come on, guess something! anything, ie: I was wasted as hell and fcked something up, I was currently doing a Jedi mind trick and magnetized the steel in the trans not letting the clutches disengage. Want another hint? Dont make me up it to $50. <------ this is not the 2nd hint, just motivation. You all are still playing to 20 bucks, If an hour goes buy WITH GUESSES we will start the betting to go up. Use all of the information you can gatherfrom any source. I Don't care how you found out..
First round of guessin is $20 from 7:30 -8:30. The ante will only go up if effort is shown. It then goes to $50 from 8:30 -9:30. EFFORT HAS TO BE SHOWN. If still no answer, but legitimante guesses have been made. The ante goes to $100 FROM 9:30 - 10:30
Do your research, figure it out. free money for you just occupying your time. If this thread takes off, I can't see why I wouldnt feel obligated to up the ante again.
HOWEVER; 11:3O IT IS DONE!!!!
RULES:
1.) I DO NOT LIE
2.) I DO NOT LIE
3 I HAVE PICTURE EVIDENCE
4 The evidence and answer will be publiclyposted tomorrow
5 The answer (if guessed correct will be revealed to the genius today, but to the public tomorrow, pending how long this draws out.
IM JUST TRYING TO HAVE SOME FUN HERE. IM HOPING TO GET EVERYONE OUT OF THEIR WORK MOOD, AND MAYBE PLAY SOME GAMES HERE
AS FAR AS THE RESPONSES GO, AND THE TIME FRAME OF THE WAGERS, A HINT WILL BE DROPPED ACCORDINGLY.
Old May 12, 2008 | 07:04 PM
Donzi's Avatar
The magnet came loose and stuck to the internals, keeping it from shifting?
Old May 12, 2008 | 07:34 PM
No, but excellent guess. Keep going.
Old May 12, 2008 | 07:36 PM
Ante is up to 50 bones baby!!!!!!!!!!!!!!!!!!!
Old May 12, 2008 | 07:37 PM
More responses = a better hint
Old May 12, 2008 | 07:43 PM
hint coming at 9:00 pm. Quality of hint still depends on action of thread. More responses/guesses, better hint.!!!!!!!!!!!!!!
Old May 12, 2008 | 08:28 PM
Donzi's Avatar
Retainer clip came off of shift leaver and got stuck in gear.
Old May 13, 2008 | 05:33 PM
FactoryJaguarTech's Avatar
Torque convertor shelled?
Front pump came loose?
Internal parking pawl rod came off and jammed up.
Found a BB had been shoved in the vent tube?
Old May 13, 2008 | 05:40 PM
Oh man Oh man, I took a pill last night in which I thought was a tylenol but was and anxiety pill called xanax or something. I don't remember anything from 8:30 on. Since I did not post the hint I promised, or the answer today..........ANTE IS UP TO 100 BONES.Here's the deal though, I found another problem which I already stated wasn't the problem. One of the drums that commonly cracks, cracked. BUT SOMETHING BEFORE THAT DRUM CRACKING FAILED, POSSIBLY CAUSING MORE STRESS. I've ordered the broken drum, new clutches and some other parts that you do not need to know about. Game is still on.
Oh, and for the hint: It's smaller in diameter than the palm of your hand. Unless you are a midget.
Old May 13, 2008 | 06:02 PM
THe input shaft snapped.
Old May 13, 2008 | 06:14 PM
stkxjrtech's Avatar
hmmmmmmmm
torrington bearing thrashed?
v-body valve stuck/ bent?
Needle bearings in tailshaft blown apart?
Old May 13, 2008 | 07:58 PM
ORIGINAL: FactoryJaguarTech
Getting warm!
Old May 13, 2008 | 07:59 PM
ORIGINAL: stkxjrtech
hmmmmmmmm
no
no
no
What wheels are on the car in your avatar?
Old May 13, 2008 | 08:08 PM
Not a lot of pressure here. Its seems kind of quiet tonight.
Old May 13, 2008 | 08:57 PM
stkxjrtech's Avatar
Theyre the factory 18" wheels, not sure about the name il find out tomorrow at work.
Front pump went south?
Old May 14, 2008 | 08:44 PM
stkxjrtech's Avatar
wheels are 18"x8" OEM "Asteroids" only came on xjr models
Old May 17, 2008 | 08:12 AM
The input shaft splined. Fell off?
I think it may be time for the answer.
Old May 17, 2008 | 04:44 PM
Donzi's Avatar
A small meteor from outer space punched a small hole in the side of the tranny case and
dented the torque converter?
robbing
Mar 5, 2024 10:51 AM
tlynch
Dec 31, 2020 01:58 PM
Msteiner
May 16, 2016 12:19 AM
dmatthewman
Sep 30, 2015 10:10 AM
rocket1lf
Sep 29, 2015 09:16 AM
