Check engine light
Old Mar 18, 2015 | 09:15 PM
Bcrary3's Avatar
Default Check engine light
Well, my idiot light is on, I don't remember the specific code, however, it is because the fuel cap is not the original one that came on the car, I do not own an OBDII scanner, and I cannot get access to one presently, I need the light turned off TOMORROW. And I have no idea. Anyone have any idea how to get this light off, even if for just a day?
Thanks!
Old Mar 19, 2015 | 02:25 AM
JagV8's Avatar
Buy OBD tool, they start at $5 so everyone can afford one
Old Mar 19, 2015 | 03:11 AM
andrew lowe's Avatar
Disconnect the battery for 10 mins or so, the reconnect.
Are you sure it is the wrong gas cap and not a blockage in the evap system?
Old Mar 19, 2015 | 04:05 AM
sparkenzap's Avatar
Three hot /cold engine cycles should do it. BTW, I assume you are either trying to get it inspected, or you are trying to sell it. If you reset the code with a scanner, you will not pass the inspection because the drive cycle will not be complete, unless you put a few miles on it, following the cycle.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
