Clock inquiry (face diameter etc.)
Old Mar 27, 2018 | 10:00 PM
King Charles's Avatar
Default Clock inquiry (face diameter etc.)
Thinking about changing up the clock's face in my car. Would like to know it's dimensions.
Old Mar 28, 2018 | 03:22 AM
cat_as_trophy's Avatar
Good question . . . can you not pop the clock+vent wood veneer panel off and measure it? It comes off quite easily. The only precaution is to work it off equally in all 4 corners without twisting.
Best wishes,
Ken
Old Mar 28, 2018 | 03:37 AM
Best wishes,
Ken
The less I handle that brittle dash the better lol. I'd like to open it once to refit clock, then be done with it.
Old Mar 29, 2018 | 05:36 PM
ericjansen's Avatar
I have one on my desk, what you want to know?
Old Mar 29, 2018 | 07:09 PM
How big is the dial/face ? My plan is to fit a high end watch's face over or replace the OEM one.
Old Mar 29, 2018 | 07:21 PM
ericjansen's Avatar
The dial/face has a diameter of 38mm, maybe a hair less (37.5mm should do).
In the original design (generation I), the face is recessed in a plastic housing.
I don't want to destroy mine, but I think you probably can remove the original face to prevent a too thick of stacking.
The center hole in the face is ~2mm.
Old Mar 29, 2018 | 07:24 PM
That's near perfect for what I have in mind ! I'm going to buy one off E-Bay to experiment w/ first.
Thanks !
Old Oct 15, 2019 | 07:40 AM
Finally found a black Rolex submariner no-date face. I plan on doing some clock surgery very soon lol.
Old Oct 15, 2019 | 07:00 PM
Addicted2boost's Avatar
Take the Jaguar face and turn it into a watch.
Old Oct 15, 2019 | 08:43 PM
Not sure I'd like that on my wrist lol.
Old Oct 30, 2019 | 01:49 AM
So apparently my "esteemed master watch smith" vendor did not measure it accurately, it is several mm's smaller than described & will just look tacky/out of place if used. On the plus side I found a local guy who is buying the dial for almost double what I paid, all's well that ends well lol.
XTYPESEAN
Jul 15, 2016 01:43 PM
Pilotman11
Apr 5, 2015 05:00 PM
worrasf
Sep 5, 2014 07:17 AM
ED P.
Nov 10, 2012 04:11 PM
xjr4life
Oct 14, 2012 06:39 PM
