Clunking noise over bumps
Old May 16, 2020 | 11:23 AM
Henkez's Avatar
Default Clunking noise over bumps
There is some clunking noise on my Xjr from back at the left side when I drive over bumps, what can be the cause of this ?
Old May 16, 2020 | 04:08 PM
Highhorse's Avatar
Sounds like shock dampers disintegrated and that pushes too easy, shocks are probably bad also.
Btw...are those 35's on those wheels? That'll intensify the ride with those shorts sidewalls.
Old May 17, 2020 | 05:19 AM
Henkez's Avatar
Do I have to replace the schocks on both sides or is it ok to replace only one side ? Can I replace the schocks at the back with regular without adaptive and still have the adaptive at the front ?
Old May 17, 2020 | 08:20 AM
motorcarman's Avatar
This is Jaguar's policy on damper replacement (warranty recommendation).
The adaptive dampers all work as a system. I would advise keeping all or replacing all with same type.
File Type: pdf
scottatl
Jan 29, 2020 11:26 PM
Holy F type
Oct 28, 2019 03:51 AM
shula
Feb 22, 2014 11:08 AM
Lenoat702
May 30, 2013 06:51 AM
