Code P0710 on my 1998 XJ8
Old Dec 21, 2009 | 12:27 PM
radar1980's Avatar
Question Code P0710 on my 1998 XJ8
Hello, this is my first post as I just found this wonderful site. I just recently bought a 1998 XJ8 despite the reviews because 1- Paid only $1500.00 CND $ and
2- I have always loved the style of the Jaguar.
I bought this car last week, put the temp permit on it, and proceeded to drive it home. The stability and traction control fail keep appearing (which I knew about) but a few days later a message appeared stating "high temperature gearbox". I got my Dads OMB2 reader and plugged it in and it spit out P0710 which I have looked up and means " Temperature fluid control sensor circuit malfunction" and P1111.
The gentleman I bought this car from showed me his bill for a remanufactured transmission costing over $3300.00, just curious of any ideas someone might have on my issue? I have been "googling" the internet for 3 hours trying to find an answer to my code P0710. I was wondering if it could be a dirty sensor and if so, where would it be located? Thanks for reading about my problem.
Paul
Old Dec 21, 2009 | 01:44 PM
scousetechie's Avatar
I think that the clue may be the stability & traction control failing messages. I had this and it pointed to a faulty battery. Since I put a new one in I have had no problems.
Jags seem to be funny about batteries, get it tested and buy a new one if it is at all suspect.
HTH
Old Dec 21, 2009 | 02:59 PM
radar1980's Avatar
Thank-you for the reply! The fellow I bought it from just actually put in a new battery because the old one failed, but I will try anything, I appreciate the response....knew I joined a great site!
Paul
Old Dec 22, 2009 | 10:49 AM
JimmyL's Avatar
Default P0710
I have read where these early XJ8s had issues with the wiring harness that goes to the transmission. I believe there was a technical service bulletin on this. I don't know if you've heard of this, but try searching on transmission wiring harness in the archives here or other forums or google. Also, if you have a subscription to Alldata they have all the TSBs there. Maybe someone else will chime in that has had the problem.
Old Dec 22, 2009 | 08:02 PM
radar1980's Avatar
Thanks for your response as well JimmyL. I did as you said and read through and the transmission wiring harness seems a likely culprit also!
I haven't had a chance to change the battery yet but worth a try as it is easy to rule out. I am going to look into this and see what I can find...just wanted some direction and every remark is very much appreciated!
Paul
Old Dec 23, 2009 | 08:13 AM
Brutal's Avatar
Forget the battery, that a temp sensor in the trans and its integral to the trans internal wiring harness. It needs to be replaced(the internal harness)
Old Dec 23, 2009 | 10:16 AM
radar1980's Avatar
Thanks Brutal! Do you think thats what is the problem with the traction control and the stability control fail issue as well?, or just the problem involving the code and high temperature gearbox message? I plan on getting it checked out after Christmas anyway but wanted a gameplan and some knowledge to guide me so very much appreciated!
Paul
Old Dec 23, 2009 | 10:58 AM
Brutal's Avatar
Has nothing to do with trac/abs, but everything to do with trans temp high. I would go to the tranny shop and see if they will warranty, even though thats not a part that would ever be replaced on a rebuild. But they may help you a little on cost, or they might just do it under warranty if theyre in a christmas good mood
Old Dec 23, 2009 | 12:15 PM
radar1980's Avatar
Again, thank-you but the tranny was bebuilt 23000kms and 3 and a half years ago so I will be on my own on this one.
Paul
Old Dec 23, 2009 | 12:29 PM
Brutal's Avatar
How talented with a wrench are you?. Its not that hard but messy on your back with trany fluid raining down
Old Dec 24, 2009 | 12:32 AM
radar1980's Avatar
I get by but usually trust others over myself as I lack confidence in unfamiliar territory.
No need to undo the tranny? I am going to look into this as I am willing to try my luck, as I stated in my first post, I didn't pay much for it so I wasn't expecting a mint car or no headaches but certainly willing to venture. I love the ride of it.
Paul
Old Dec 24, 2009 | 10:15 AM
Brutal's Avatar
No you just drop the pan and replace the trans internal harness that goes to shift solenoids, sensors etc....and its color coded and layed out as it run. Just take before pics to referrance layout and harness run through retainers
Old Dec 24, 2009 | 02:38 PM
radar1980's Avatar
Thank-you again, I will venture into this after Christmas! Happy Holidays and thanks for the advice!
Paul
Old Jul 11, 2016 | 03:46 PM
JagJulian's Avatar
hey fellas. did that work all those years ago?
Old Jan 19, 2021 | 11:55 AM
my2000xj8's Avatar
Radar1980 I have all the same codes going off in my 200 Jaguar xj8 curious to know what fixed your problem
Old Jan 19, 2021 | 01:14 PM
motorcarman's Avatar
ELEVEN plus years??????????
WOW
CarGuy
Jan 18, 2017 06:25 AM
MDMike
Dec 3, 2015 06:34 AM
kenncl
Jun 17, 2010 09:02 PM
mark@ddi
Sep 19, 2008 10:53 AM
listenloud
Jun 5, 2008 09:22 AM
