which code reader for this connector
Old Jul 31, 2015 | 06:51 PM
xj8route66's Avatar
Question which code reader for this connector
which code reader fits this connector on a 2003 XJ8?
Old Jul 31, 2015 | 06:54 PM
CharlzO's Avatar
That's a standard OBDII connector that pretty much anything will hook to these days. I'd be concerned about what looks to be some pretty decent corrosion on the end. Personally I use a bluetooth OBDII adapter and the Torque app on my smartphone, but it's a standard plug after the mid-90s? earlier? Almost any scanner should work, especially new ones.
Old Aug 1, 2015 | 07:19 PM
Lear45's Avatar
Any OBD2 reader. A blue tooth reader that works with a cell phone is convenient for the basics. You need to spend $$$ to read SRS etc. I too would be concerned about the corrosion.
Old Aug 1, 2015 | 08:55 PM
test point's Avatar
Every reader on the market is discussed here:
https://www.jaguarforums.com/forum/g...oved-**-33347/
My vote is with the TORQUE Android app. The simple reason is that it is a full function system and cost less than $20, about $7 minimum, to implement and has a lot of features that readers costing hundreds do not have.
I have fond hopes that the app's capabilities will be expanded with upgrades costing only a buck or two.
Old Aug 2, 2015 | 03:17 AM
andrew lowe's Avatar
Plus one on the blue tooth adaptor and Torque Pro Android app.
With a free bolt on (track recorder) it even turns your phone into a dash cam!
Bcrary3
Sep 12, 2021 05:41 AM
cissdm
May 3, 2016 06:02 AM
Ragn0r
Sep 19, 2015 08:39 AM
jagfool
Sep 14, 2015 07:50 PM
tonyforman
Sep 10, 2015 07:23 PM
