Codes found!
Old Feb 29, 2008 | 06:07 PM
Donzi's Avatar
Default Codes found!
2000 XJR 65K miles
Checked as a result of check engine light and performance restricted message.
here are the codes that showed up
P0171
P0174
P1111
I cleared them all,
then under acceleration the P0171 came back. The scanner shows it as bank 1 lean.
I do feel under mild acceleration, it slightly stumbling a tiny bit........
Ideas?
Thank you all for your help.
Old Feb 29, 2008 | 06:17 PM
jag_genius's Avatar
Default RE: Codes found!
right side bank (1) may have avacuum leakat air intake after mass air flow sensor..you can smoke test the intake or here for a leakor it may simplyneed a MAF sensor
Old Feb 29, 2008 | 06:39 PM
Donzi's Avatar
Thank you JG.
I will check it out.
Old Feb 29, 2008 | 07:16 PM
Donzi's Avatar
JG I just checked the air intake from MAS to throttle body, smoke and noise indicate no
obvious leakes. But I did notice a bit of oil in the air intake tube, no doubt from the PCV fitting......is the oil in the air intake normal?
Also the air intake tube does not seem to be real tight where it goes on top of the throttle body....is there supposed to be a clamp on it there?
Could that be the culpret?
Old Feb 29, 2008 | 07:35 PM
FactoryJaguarTech's Avatar
That could cause lean codes. I have also seen several intake tubes cracked at bottom cause it.
I would look at fuel trims while accelerating. If -20% put a mass air flow in it.
Old Feb 29, 2008 | 07:42 PM
Donzi's Avatar
Will do,
I pulled the tube and checked it very well, no apperent cracks anywhere.
I am leaning towards the MAS.
Thanks!
Old Mar 1, 2008 | 09:10 AM
Donzi's Avatar
Would that also explain the stumbling at around 3000 RPS....but clears out when I get on the throttle hard and pass 3000 rpms?
Old Mar 1, 2008 | 06:22 PM
It can, hard to say without being there. Look at fuel trims though.
Old Mar 2, 2008 | 07:17 PM
Donzi's Avatar
Fuel trims while running are all in the +0 to +25 Unless I am off the throttle completely when coasting up to a light.
Then SOMETIMES they drop to as much as -30 but very rarly......what is the correct procedure for checking the Fuel Trim on the scanner?
MAF also seems good on the scanner. It goes way up and down directly realted to the engine speed.
Whats the next step? Throttle body clean or change out completely?
I really want to get this car running puuuuurfectly.
Old Mar 2, 2008 | 09:05 PM
Are you talking %?
Sit at idle and see what the trims are.
Then put handbrake on, put car in drive and keeping foot on brake, bring RPM up to about 1200 or so. Dont let car move. See what they are. Then drive under light acceleration and see initially what it reads.
Old Mar 2, 2008 | 09:32 PM
Donzi's Avatar
Yes sir, that is in %
I will do that tomorrow and post the results.
I truly appreciate all of your help!
Old Mar 3, 2008 | 07:18 PM
Donzi's Avatar
Problem fixed! A new MAF sensor did the trick!!
Thank you all for your help!!
Old Mar 3, 2008 | 07:45 PM
ibjags's Avatar
quite common fault
congrats on the fix
Old Mar 3, 2008 | 08:58 PM
good job!!
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
joesoap
Sep 10, 2015 01:09 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
