coolant temp
Old Mar 30, 2011 | 01:38 PM
Thundercat's Avatar
Default coolant temp
Hey Guys,
Just installed a autometer water temp guage in the 3/4 inch heater hose. The guage is only reading about 125 degrees MAX. does anyone know what the normal coolant temp is at running temp?
Old Mar 30, 2011 | 02:29 PM
Doug's Avatar
The temp should be, at minimum, whatever the thermostat rating is....probably about 195ºF/88ºC. Temp reading at a heater hose isn't really relevent.
Old Mar 30, 2011 | 02:57 PM
Thundercat's Avatar
which hose should I tap into?
Old Mar 30, 2011 | 06:59 PM
pdog2000's Avatar
same place the current temp gauge goes into...try to see if you can use a T
pdog2000's Avatar
doug...on a side note where did you put the gauge? pillar? post a pic
Old Mar 30, 2011 | 09:34 PM
luc's Avatar
luc
Originally Posted by Thundercat
Hey Guys,
between 190 to 230
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
3lvis
Oct 1, 2015 01:56 PM
dmatthewman
Sep 30, 2015 10:10 AM
