Cooler hose spider mess
Old Dec 14, 2020 | 06:15 PM
Desertdawg's Avatar
Unhappy Cooler hose spider mess
After getting everything back together from a front timing replacement, I discovered a water leak when filling the rad. It's coming from the mess of hoses and wires below the throttle body. It can only be coming from the bundle of rubber hoses that tie the throttle body, water reservoir, engine water pump, small electric pump below the water reservoir, and another hose back below the firewall. What a mess! Who ever thought of this route should be shot! Anyway, I'm just venting.
So a kit that somewhat resembles my spider maze is over $100 and I'm not sure it's the same. Has anyone just made up an assembly with high quality heater hose?
_____________
1998 XJ8
Old Dec 17, 2020 | 05:55 PM
I've copied your question from General Tech Help for advice from members with the same model.
Old Dec 18, 2020 | 06:20 AM
Highhorse's Avatar
The octopus as its known, is what it is. Definitely suggest OEM if you can get it. Yours is over 20 yrs old probably (if not being replaced before), so you got a great life out of it.
Old Dec 18, 2020 | 08:08 AM
M. Stojanovic's Avatar
The attached parts diagrams should help you establish what hoses you need.
File Type: pdf
Old Dec 18, 2020 | 09:39 PM
Desertdawg's Avatar
Perfect!! I am buying it, including the water pump feed and return hoses. Thanks!
Old Dec 18, 2020 | 09:40 PM
Desertdawg's Avatar
will do. Thank you very much.
Desertdawg
General Tech Help
Dec 15, 2020 05:20 PM
kenc
Aug 23, 2020 05:33 PM
Truck Graphics
Nov 28, 2015 02:14 PM
cleveland
Dec 15, 2009 07:34 PM
SeattleXJR
Sep 30, 2008 07:48 PM
