cruise control will not engage
Brake switch at RockAuto. com is $39.79 less 5% promo code (58706B0C3F9D33) net $37.80 plus shipping Fedex ground $8.87 (3 to 4 days) total $46.67.
Details: 2000 JAGUAR XJ8 4.0L V8 Electrical-Switch & Relay : Brake Light Switch
AIRTEX / WELLS # 1S12145 {#LNB6420AA, LNB6420AB, LNB6420BA, LNB6420BB, SW9225
weblink:
2000 JAGUAR XJ8 Brake Light Switch
Jim Lombardi
weblink:
Jim Lombardi
weblink:
Jim Lombardi
weblink:
Jim Lombardi
I usually check Rock Auto .com to see if they stock any of my needed parts, they are usually the lowest price on quality parts. The brake switch they sell is usually about $120 elsewhere.
I also shop online with Advance Auto Parts and see if they have the part I need, but they did not have a lot of Jaguar parts.
They do have a lot of great promo discount code to apply to most of their online merchandise ( TRT30 - 30% off your order -- maxium savings $50 ie -- $166.66 purchase nets down to $116.67 -- $50 savings).
Here is promo code for them:
WD46 -- $10 off order over $25, $20 off order over $50, $30 off order over $75, $40 off order over $100, $50 off order over $125. Online only.
You can order your stuff online and use pickup at your local store option, most times the store has it in stock and you can pick it same day.
Jim Lombardi
Jim Lombardi
I have replaced the brake light switch on my 2000 xj8 as recommended by so many of my forum families members . LET THE CRUISING BEGIN . The cruise control works perfect .Thanks for all the imput and advice
Jim Lombardi
Jim Lombardi
Great advice all aroung . I look up Old Mike post as you recomended. good stuff thank you
The earlier '97-'99 XJ8's had there cruise controlled opeated by vacuum acumulators....easily spotted with black round can on left side of TB.
The later....late'99-'03 models switched to full electronic system to operate cruise....no black can on side of TB ;o)
Johnken
Sep 22, 2015 03:53 PM
