Differential Output Shaft Bearings
Old Jun 1, 2016 | 12:26 PM
l3uddha's Avatar
Default Differential Output Shaft Bearings
Has anyone found a cheaper alternative to the JLM20337 bearing that is not as absurdly overpriced as the OEM part? Maybe a Timken or something else? Thanks
Old Jun 1, 2016 | 01:27 PM
andrew lowe's Avatar
I can tell you it is an SKF bearing, with a part number that looks to be "13 13 1 13 1 8 8 2 0 2 ITALY V "
Having said that, the 13's could be B's . Hope this is of some use.
Old Jun 2, 2016 | 04:05 AM
Addicted2boost's Avatar
I would measure the O.D., I.D. and width with a caliper micrometer, then proceed over to McMaster-Carr website and choose a bearing. I know they aren't the cheapest, but you'll get it quick. Whatever you decide, could you please post a P/N for future reference?
Old Jun 12, 2016 | 11:27 AM
Mvirgil's Avatar
I believe the thickness of the bearing is a few MM too large for same OD deep grove single row bearing.
SKF bearing: BB1B 1862021 B
72mm OD, 29mm Wide, 35mm ID
Seal on inside, shield on outside
I dont want to say a 27mm +2mm shim is a good idea
Old Jul 28, 2016 | 10:05 AM
Col. Sandurz's Avatar
So does this work? As in this part number but a shim is needed? About to look into mine, may be time to do something.....
Old Jul 31, 2016 | 10:50 AM
Mvirgil's Avatar
The SKF # is the exact bearing jaguar uses.
Typical bearings of the same OD and ID are 27mm vs the 29mm (our 14hu output bearings). So a 27mm double row angular contact bearing +2mm shim and +2mm camber shims could work (but i don't think its the best solution)
i don't believe 72mm OD is a standard metric shim size
aquifer
Jun 3, 2016 09:08 PM
nicobenny
Jun 1, 2016 11:24 AM
Vee
May 31, 2016 05:09 PM
Safari
May 26, 2016 10:33 PM
