Do I really need timing chain tensionig tool 303-532
Old Oct 15, 2014 | 03:10 PM
blackhonor9's Avatar
Default Do I really need timing chain tensionig tool 303-532
I am changing my timing and would like to know if I really need tool 303-532 to set the timing? I know I need the camshaft locking tool 303-530 but why the 303-532?
Old Oct 15, 2014 | 03:40 PM
cobac's Avatar
When I did mine, I didn't think the tool was totally necessary either until I got the car apart. But I was sure glad I had it when I started the job.
The tool, with a breaker bar attached to it, attaches to the holes in the sprocket. It let's you put opposite pressure on the sprocket while you apply opposite pressure on the sprocket bolt - to remove or install the bolt.
The sprocket bolt is torqued really tight, so in addition to the tool I'm happy I also had a large torque wrench to tighten it up properly when finishing the job. The ball ended allen socket is also another must have for getting that bolt on/off if you're not removing the front timing cover.
Old Oct 15, 2014 | 03:44 PM
plums's Avatar
Depends on the job.
If you are doing only the upper tensioners with no other problems and using the ziptie method, then no.
Old Oct 15, 2014 | 05:04 PM
Can you tell me what the zip tie method is?
Old Oct 15, 2014 | 06:28 PM
rocklandjag's Avatar
The zip-tie method secures the timing chain to the camshafts and then you lift the exhaust cam up enough to remove and replace the secondary tensioner. The sprockets are not removed at all. If you do a search of this and/or the XK8 forum you will find tons of information on this method. Just be sure to position the exhaust cam so that there is no valve spring tension on the exhaust cam before you remove the caps
Old Oct 15, 2014 | 10:00 PM
motorcarman's Avatar
I have the Jaguar factory tool but I like my home made tool better.
It is double sided so it fits better in different positions of the sprocket.
A piece of steel and a hole saw to cut the round part where the large sprocket washer goes. Just weld in some 5/16" or 8mm round stock for pegs.
You can weld a socket to the metal for a break-over bar or just use an open end wrench like I do.
bob gauff
Attached Thumbnails Do I really need timing chain tensionig tool 303-532-dsc02386.jpg   Do I really need timing chain tensionig tool 303-532-dsc02387.jpg
Old Oct 17, 2014 | 03:40 PM
Thanks for all the information. I decided to purchase the tool set. I wanted to make sure the job is done correctly.
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
philwarner
Sep 5, 2015 10:05 AM
Bowman
Sep 3, 2015 03:17 PM
