Do the X308 have a remote fob flip key?
Old Sep 21, 2011 | 06:22 AM
jimmyfct's Avatar
Default Do the X308 have a remote fob flip key?
Anyone know if I can order a remote flip fob key like the X350 for my X308?
regards,
Jimmy
Attached Thumbnails Do the X308 have a remote fob flip key?-jaguar-remote1.jpg
Old Sep 21, 2011 | 08:31 AM
JaguarXJR02's Avatar
I don't think they sell that it would have to be a custom job
Old Sep 21, 2011 | 05:31 PM
burmaz's Avatar
regards,
Jimmy
What year is your car? I bought a fob from a 2001 X308 for my 2000 which operates on the same radio frequency, and the fob DIDN'T work. Not sure if this is relevent for you, but it was stated on this forum that a 2001+ X308 would work for a '98-2000.
Old Sep 21, 2011 | 07:05 PM
Stu 1986's Avatar
I have never understood the point of these flip keys to be honest. I mean why must the car key be folded away when the rest of the keys on the keyring are exposed? We have a few VW company cars with flip keys and they pop open in your pocket anyway.
But on the subject of the getting one for the X308, I'm doubting they'd be compatible.
Old Sep 22, 2011 | 04:27 AM
Cadillac's Avatar
I think you will also have to change all the parts related to keys such as door locks, ignition key hole,trunk's key hole . I would like to have an upgraded system as yours too , but it's not worth the money
Old Sep 22, 2011 | 05:12 AM
jimmyfct's Avatar
Default Thank you for all advice
I'm looking for the flip fob key, because when driving sometime the remote part is touching my leg! Hope if I can upgrade the key the I can solve this problem. Any Idea how can I custom it?.
Old Sep 22, 2011 | 10:16 PM
plums's Avatar
Well, the fob does not actually have to be on your keyring. It can be in your pocket for example. Having two methods into the car is helpful in preventing lockouts.
Old Sep 23, 2011 | 01:46 PM
Sean B's Avatar
remote touches your leg? ah bless you, it must be a real downer to the day! raise the wheel?
Old Sep 25, 2011 | 10:53 AM
the remote touching the leg is a pain I agree, I usually just try to ignore it, but if I am going to be in the car for a while I break out the valet key by itself for the ignition
as far as custom fitting it, there would be a lot of highly advanced maneuvers required. the keys have a computer chip in them for security and anti-theft purposes. so you couldn't just cut up the key and solder/weld/glue it to the "switchblade key" mechanism. you might be able to get the key security chip out of the key and then put it inside of the switchblade box, I'm not sure.
and then the buttons in the remote are basically on a computer chip, and I would think that the switchblade key's computer chip has a relatively different dimension as far as fitting the computer chip in there.
Old Sep 25, 2011 | 12:28 PM
jimmyfct's Avatar
Default Thank you for all your kind advice.
I think, I had to live with it then. May be someday, some guy will work it out and sell them.
Old Sep 25, 2011 | 06:15 PM
QuadManiac's Avatar
I put a small circular patch of self adhering velcro on the back of the fob, a mate to it on the steering column - now when I drive in shorts, I stick the fob to the column - no more annoying brushing against my leg.
Old Sep 26, 2011 | 02:15 AM
JagScott's Avatar
I tried syncing an 05 jaguar xjr key to my 98 xj8 using the usual method (except turning my 98 key in the door and pressing the 05's buttons). The 05 xjr will actually lose sync with the FOB when I do this with the 98 xj8. Sorry, it just doesn't work. I'm sure if you spent lots of money and got a few hardware and software programmers, you might be able to do this. But doing it the "easy way" isn't going to happen.
peterg19
Feb 10, 2023 09:02 PM
kevinl
Sep 24, 2015 08:25 PM
SeanU
Sep 18, 2015 03:38 AM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
