Does anyone have a pdf file, etc. on removing the driver's door latch on a XJ8?
Old Apr 26, 2013 | 02:11 PM
robertjag's Avatar
Default Does anyone have a pdf file, etc. on removing the driver's door latch on a XJ8?
Thanks!
Old Apr 26, 2013 | 02:39 PM
RDMinor's Avatar
Go here to the X350 download link and download section #5 Workshop US006 5. Body & Paint PDF and go page 416. That should step you through it.
http://www.mediafire.com/?x11yhijup29yt#8viyccmusy9t1
Good luck
Old Apr 26, 2013 | 03:05 PM
Red October's Avatar
I'm not aware of a pdf file purely for the door latch removal-however, you can download the complete JTIS from this website which will include everything-including door latch removal
Old Apr 26, 2013 | 08:45 PM
robertjag's Avatar
Good luck
Does it make a difference that this link is for x350s years 2004 thru 2010 and mine is a 2001?
Old Apr 26, 2013 | 08:47 PM
robertjag's Avatar
Thanks Red,
I have those 3 files on my office computer and just have not transferred them home. Thought someone might have remembered a link to a write up on how to remove them (with tips often not found in the JTIS).
Robert
Old Apr 26, 2013 | 10:01 PM
RDMinor's Avatar
I'd bet the only differences are cosmetic
Old Apr 27, 2013 | 05:36 AM
jimlombardi's Avatar
Hi Robert
Here are PDF files for your XJ X308 door latch Removal & Install extracted from the JTIS.
Driver Door Latch:
https://www.dropbox.com/s/g1ahp1taof...74%20R%26I.pdf
Passenger Door Latch:
https://www.dropbox.com/s/nzyje50udl...75%20R%26I.pdf
Front Door Trim:
https://www.dropbox.com/s/z7t6drcmh8...2076.34.01.pdf
Front Door Armrest:
https://www.dropbox.com/s/bvixuhw0of...2076.34.22.pdf
Front Door Trim Panel:
https://www.dropbox.com/s/zbjg4sl9v0...2076.47.11.pdf
Jim Lombardi
Old May 12, 2013 | 11:59 AM
robertjag's Avatar
Originally Posted by jimlombardi
Hi Robert
Driver Door Latch:
https://www.dropbox.com/s/cj1ho6la66...74%20R%26I.pdf
Front Door Trim:
Front Door Armrest:
Jim Lombardi
Thanks Jim! Sorry to get back to you so late. I have been swamped at work and have not had any car play time!
Robert
Old May 12, 2013 | 07:54 PM
Lear45's Avatar
If you are replacing the cable, do not remove the latch. I changed my cable by doing the following.
1. Have window in UP position
2. Disconnect the battery
3. Carefully pry off the little 1/4" round screw cover that holds the interior handle trim
in place.
4. Remove the screw on underside of the arm rest.
5. Use plastic trim removal tools and carefully pry the door panel loose.
6. The wood trim pries and then slides off.
7. Once you have access to the handle remove the old cable.
8. Use a inspection mirror to see how the smaller end of the cable attaches.
9. Once that is attached then attach the other end and reassemble everything.
It took me about an hour since I tried to remove the actual latch and finally figured out that was no necessary.
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
jagent
Aug 30, 2015 08:42 AM
Jaguar Forums Editor
Jaguar Press release
Aug 27, 2015 03:18 AM
