Door handle screw cover.
Old Feb 4, 2014 | 03:21 PM
don reeder's Avatar
Default Door handle screw cover.
How do you remove the screw cover in the front door handle insert on a 2002 XJ8?
Old Feb 4, 2014 | 03:28 PM
dsnyder586's Avatar
With something very thin...razor blade or such. They are not in there very hard so once you get it started it goes easy.
Old Feb 4, 2014 | 05:35 PM
jimlombardi's Avatar
There is a video on removing the rear door panel that shows the tools they used.
I used the snipping tool in windows 7 and pasted the photo of the small screwdriver (for the small plastic plug) into first jpeg file, also the photo of the upholstery tool (for prying the clips that hold the door panel on) in the second jpeg file.
Jim Lombardi
Old Feb 4, 2014 | 09:00 PM
Blue_XJ8's Avatar
Yes, I was able to remove it with a little "watch screw size" screwdriver. Be gentle, easy to scratch/mess up the plastic.
Old Feb 4, 2014 | 10:13 PM
grandell's Avatar
I always found a razor blade or craft knife worked best, screwdrivers always seemed to damage the plastic
The other thing is to make sure you catch it once it pops off! They can be hard to find if they flick out and end up on the ground
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
