Easy Fix
Old Jul 16, 2014 | 06:33 AM
jrb53's Avatar
Cool Easy Fix
This has to be the quickest fix yet had a Po356 fault bad coil #6. undo 6 bolts holding cover over coils then remove 2 bolts holding coil in place takeing care to remove plug on coil. then replace with new coil plug in reinstall. job done....
so now my question is should I replace the rest of the coils, or is it a case of IF it aint broke don't fix it thanks JRB53
Old Jul 16, 2014 | 07:49 AM
xjay8's Avatar
JRB...you answered your own question ;o))
These coils don't like being messed about with any more than is necessary
and you need to be doubly careful with the wiring harness and connectors
as they heat harden with age.
A couple little tricks with these is to remove the boot and 'stretch' the contact spring just a little bit for a firmer contact and place a little di-electric grease around the rim of the boot where it contacts the plug porcelain.....do it to one, you do it to all of them....check for any corrosion.
And while you're at it, you may as well pull th eplugs and check them....when were thay last done?
Old Jul 17, 2014 | 05:55 AM
kyle04's Avatar
I has 2 coils pack up within a month of each other - I replaced the first one and thought nothing of it but when the second one died I decided to replace the lot with aftermarket ones. So far so good a year later, and I have a few spare old coils if one packs up.
I would at least invest in one or two extra coils in case of another failure, at least you can fix it there and then....
Old Jul 17, 2014 | 06:24 AM
jrb53's Avatar
thanks for the advice I change the plugs last year with NGK plugs,will be buying a couple of spares.they only cost $26 on ebay
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Richard_gib
Sep 12, 2015 07:08 PM
kstevusa
Sep 7, 2015 01:12 PM
