electrical problem...got nothin
Old Feb 16, 2020 | 04:17 PM
Dave Redline's Avatar
Default electrical problem...got nothin
hello,
I was installing my ebay cd changer with no key in the ignition, plugged it in,put the key in the ignition turned to on. The antenna didn't go up and I got no read out on the radio. I turned
the ignition off and unplugged the changer. I now have nothing, no lights, no horn, no starter, no seat adjustment nothing. I have checked all the fuses I can find, engine bay,
trunk. all fuses check out ok. I'm hoping for suggestions. This car is a 2000 xjr. Any help will be greatly appreciated.
Thanks,
Dave
Old Feb 17, 2020 | 03:46 PM
Highhorse's Avatar
Check the ground lanyard cable coming off the battery. They can go bad, mine did...twice I got a total loss of power, as you describe it before I found the issue on mine.
Other than that, review the attached pdf's....
Old Feb 20, 2020 | 03:40 PM
Default Thanks
Hey Highhorse,
Thanks a heap, the lanyard was the problem. I would have never found it, what a relief.
thanks again
Dave
AZXKR
Feb 12, 2017 08:25 PM
vicsrc
Nov 17, 2014 08:03 PM
direng
XJ40 ( XJ81 )
Jan 9, 2012 11:31 PM
