Engine Coolant Temperature Sensor
Old Sep 24, 2020 | 08:59 PM
Dreamjags's Avatar
Default Engine Coolant Temperature Sensor
My 2000 x308 has developed a cold start issue, drives fine.
After a few min drive it will start normal.
Is this the most likely culprit?
Old Sep 24, 2020 | 09:16 PM
xalty's Avatar
Check OBD readout
Old Sep 24, 2020 | 10:05 PM
NBCat's Avatar
Is the MIL on?
What DTCs are stored in the system?
Old Sep 25, 2020 | 06:21 AM
Dreamjags's Avatar
No check engine light so I have not checked for codes. I will check after I get off work
Old Sep 25, 2020 | 11:25 AM
Dreamjags's Avatar
P1000 is the only code showing. Again no CEL.
Old Sep 25, 2020 | 11:30 AM
NBCat's Avatar
What is the fuel pressure with the ignition in the ON position without engaging the starter? It should be around 3 bar.
Fuel pressure can be checked via the schrader valve on the engine fuel rail, or through the PCM with a smart phone and the Torque app connected by the OBD port.
Old Sep 25, 2020 | 12:30 PM
Dreamjags's Avatar
Pouring out now but will be back
Old Sep 25, 2020 | 02:01 PM
Jhartz's Avatar
Dreamjags: where are you located? If you are already into cold morning starts, it is most likely the temperature sensor (your photo). Frequently the issue once the cold weather arrives in North America. Most folks buy a new crossover pipe which usually includes a new sensor. But if your OBD reader can read codes, you might also be able to read the actual temperature change in real time: if so, not likely the sensor.
But put your location in the box in the upper right corner.
Old Sep 25, 2020 | 02:52 PM
Dreamjags's Avatar
I'm in Virginia, mornings in the 40s when this occurred. Is replacing the whole crossover pipe easier seem like the sensor is easily accessible. Still raining but fuel pressure reading coming once it's dry.
Old Sep 25, 2020 | 04:50 PM
avern1's Avatar
It is possible that the problem is the fuel pressure regulator. Give this a try and see how it starts. Turn the key to position 2 and let the dash sequence process and then turn key off. Do this 2 more times. Then start as normal. Is the cold start improved? If so the pressure regulator is allowing overnight or sitting to allow the rack pressure to drain off and when you try to start the 3 to 5 second fuel pump initial run on switch position 2 isn't sufficient to recharge the rack.
Old Sep 27, 2020 | 08:48 AM
Dreamjags's Avatar
Hood latch broke. Added an unexpected project to the weekend. Got that taken care of. Question on the temp sensor. I'm seeing 2 parts listed. AJ810031E & LNA1600AA
​​​​​​Got this shot with my endoscope camera for future people dealing.
Old Sep 27, 2020 | 09:27 AM
M. Stojanovic's Avatar
AJ810031 is for later AJ27 and LNA1600AA is for earlier AJ26 engines. From your first picture, it looks like you need AJ810031. Anyhow, compare your old sensor with the pictures:
Old Sep 27, 2020 | 06:46 PM
Dreamjags's Avatar
Popped in a new sensor, was the old style. AJ26 Ive learned. Fired up nicely after switching will see about the morning.
badicedog
Sep 8, 2019 06:23 AM
Braydon
Apr 6, 2019 04:37 PM
oldmaned
Jun 21, 2014 09:19 AM
georgia boy
Jan 26, 2011 08:47 AM
