Engine Fail Safe mode
Old Sep 23, 2025 | 08:30 PM
3timejag's Avatar
Default Engine Fail Safe mode
I am experiencing an intermittent Fil Safe mode and the cruise control gets knocked out too. Any insight on what may cause this to happen? It resets when I turn the car off and the restart, but eventually it comes back.
many thanks in advance
Old Sep 24, 2025 | 02:09 AM
JagV8's Avatar
It's protecting itself but struggling to say why.
Try OBD. You probably won't find any codes but might find pending ones. (Don't clear any!) Check live data for any odd values. Check all OBD monitors are set (aka complete) and if any aren't then they are clues.
Old Sep 24, 2025 | 03:01 AM
Hooli's Avatar
Aye start by reading codes, but I'd guess at the brake light switch as that works with the cruise control too.
Old Sep 24, 2025 | 03:28 AM
Peter_of_Australia's Avatar
Yes, check the OBDII codes.
I bought my X308 in such a condition way back, and in my case it was the knock sensor that wanted to get replaced, The OBDII reader told me as much, too.
Old Sep 24, 2025 | 10:35 AM
Lear45's Avatar
Default fail safe
Fail Safe for me was a failing transmission. Overhauled it and zero issues since. Read codes though.
Old Sep 24, 2025 | 10:38 AM
3timejag's Avatar
Transmission is fine, but I am familiar with this possibility from previous Jags I've owned, thanks
XKDreams
Jun 12, 2024 04:31 AM
captainobvious1
May 14, 2024 08:33 AM
asjdhsajhdfj
Jun 28, 2023 06:49 PM
joec
Dec 22, 2013 08:22 AM
djsomebody
Jul 18, 2011 08:16 PM
