Fixed my ABS/Trac error in an odd way :)
Old Dec 1, 2013 | 01:39 PM
Mikey's Avatar
Originally Posted by Jhartz
Reread the first post . . .
I did. Installing new pads should not cause the reservoir to be 'full full' (overfull) unless somebody added fluid to the system with worn pads in place.
That's a common enough error.
Old Dec 1, 2013 | 02:07 PM
WaterDragon's Avatar
Originally Posted by Mikey
I'm just wondering how the master cylinders became 'overfull' in the first place. They didn't leave the factory like that (?)
Yes,
As the pads wore down to near nothing, the fluid level went down. I topped it off the the full level.
As I said in my first post "where someone repeats my error of leaving the brake fluid level too high"
Yes, when the new pads were installed, it pushed the pistons back on all 4 corners, a lot. The fact that this then caused an overfull situation is then not surprising, or even uncommon, as you said, so why you surprised that this happened then?
The point of my post was that it fixed my ABS light problem for good. To this day that car has had zero abs light issues. That was the main point of my post, my motivation was to be helpful to this community. Given a few others have reported this odd fix worked for them, then this post was helpful. So, to that end, I am happy I posted it.
What is the motivation for your post?
Question: Are you still using the same fluid that was installed from the factory? ? Because that would be (insert word here)
Old Dec 1, 2013 | 02:53 PM
Mikey's Avatar
Originally Posted by WaterDragon
As the pads wore down to near nothing, the fluid level went down. I topped it off the the full level. ............
.........Question: Are you still using the same fluid that was installed from the factory? ? Because that would be (insert word here)
No I'm not- but I refill the reservoir to the same level as before the flush, not necessarily to the full mark. Doing so would induce an overfull/overflow condition when new pads are fitted.
Adding fluid with partially worn pads is not required. The reservoir contains enough fluid to accommodate four sets of fully worn pads and still be within acceptable limits.
aholbro1
Dec 29, 2024 06:46 PM
scooternva
19
Oct 27, 2015 02:14 PM
Lannyl81
Sep 19, 2015 08:07 PM
tberg
Sep 17, 2015 10:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
