Fog Light Issue 1999 XJ8
Old Mar 25, 2009 | 05:54 PM
JagtechOhio's Avatar
Often times a bulb filament failure will cause a short and blow the circuit fuse. I don't know from memory where that fuse is located, have a look in your owners handbook and it will likely tell you it's in the right engine bay fusebox.
Old Mar 26, 2009 | 01:11 PM
SuperSport's Avatar
Originally Posted by mkhall22
Thanks for such a speedy response!
Would that cause just ONE fog light to go out? Does anyone have a link to a fuse box diagram?
My manual shows the headlights separated left/right with fuses, but the fog lamps combined, at fuse 17 front left-hand engine compartment.
My guess would be the socket. My Hummer used to have problems with the sockets. Clean it well with WD40 and see if that helps. You could also put a tester on the socket to see if any voltage shows up. Likely, if the bulb does not light, then there won't be, but this will rule out a faulty NEW bulb.
Attached Thumbnails Fog Light Issue 1999 XJ8-fuse-locations.jpg   Fog Light Issue 1999 XJ8-fuse-locations-2.jpg
Old Mar 26, 2009 | 02:12 PM
Quite correct and verified, thank you for correcting my mistake.
Old Mar 26, 2009 | 02:17 PM
SuperSport's Avatar
JagtechOhio, I didn't mean to make it sound that way. I respect your oppinion GREATLY! I just happen to have the manual on my computer in PDF.
PS: Until I read this, I never knew the headlights were seperate. Good info for future.
Old Mar 26, 2009 | 03:53 PM
Thanks for the kind words, mine were sincere as well. Part of being a credible source means making sure you get it right when you're wrong. My answer was expedient, yours was accurate, and I thank you for it.
Old Mar 28, 2009 | 08:55 AM
jag_genius's Avatar
check the connector i think it s a 6 pin on the right side lower bumper.. might have corrosion or broken wire at the connector
SD96XJ6L
Jan 12, 2022 04:30 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jimscriv
Nov 4, 2015 02:18 PM
thedugger1
Sep 24, 2015 05:32 PM
bigw909
Aug 30, 2015 09:29 AM
