Fuelpump - confusion
Old Feb 14, 2019 | 04:29 AM
bongobrown's Avatar
ok...thats a great idea I think I can handle myself - just solder the bridge and plug it in. Seems easy. Problem is that when I attempted to insert a paper clip "in both relay1 and 2" it just sparked a bit when inserted - turning the kay afterwards and try to crank...but no change. So I guess this points at the a faulty pump or connection elsewhere.
I have lots of good advises to follow - not all I can do myselv bc lack of knowledge but am tyring to convince my mechanic to do the job .
If I need to check if the relays are actually working/clicking - can I connect them to second battery or how do I do that ? - as mentioned earlier I have only used my amp-meter to check for bridge connection between 30/87 at the relay.
thanks
Old Feb 14, 2019 | 05:20 AM
M. Stojanovic's Avatar
Connect 12V to the relay pins 1 and 2 (or 86 and 85, if that is how they are marked) and listen for the clicks.
Old Feb 14, 2019 | 10:58 AM
bongobrown's Avatar
great thank you..Ill try that.
Old Feb 19, 2019 | 03:26 AM
bongobrown's Avatar
If the schrader valve is working when pushing a scewdriver into the hole and it sprays up with gasoline..seems like there is plenty of pressure - but did not messure it in PSI.
Question is: if pressure is okay on the schrader valve (test fuel valve from the engine room)- does this indicate that the fuel pumps are intact ?
...just before I order two pumps.
What point in another direction is that I do not hear a clear sound from the pump in the trunk when turning the ignition on...so that tells me the pump is not working.
I know things are complicated and it can be many things like bad connection etc..as you guys already guided me.
Just wanted to know if the test valve is working - what does is say about the 2 pumps conditions ?
Thanks again
Old Feb 19, 2019 | 08:14 AM
When you turn the ignition on, only the Pump 1 will briefly, for just a few seconds and stop. Difficult to hear it when it runs for such a short period of time. You cannot test Pump 2 using the ignition key. As suggested earlier, make a short jumper wire with spade terminals at each end and plug it into the sockets of the two pumps, one at a time, and listen for the pump sound at the filler neck while having the flap pushed open with a screw driver. You don't need to switch the ignition on for this test.
Without a pressure gauge, you cannot tell how healthy the pumps are. The fuel sprays out from the schrader valve but how strong it sprays?
Old Feb 19, 2019 | 09:11 AM
bongobrown's Avatar
good point and thanks...I have tried jumping the replay without any results...besides some sparks when inserting the paperclip. I will try with the spades ends as you suggest and see if this changes anything.
Before that I have tested the relays with as 12a batteri - and they both clicks nice.
Also, seems like I need to find a fuel pressure gauge to test. Anybody know how much psi it should be ?
Old Feb 19, 2019 | 11:01 AM
About 44 psi when the engine is not running, 38 when running (idling).
Old Feb 20, 2019 | 01:18 AM
  #28
bongobrown's Avatar
great thx alot
Yves.S
XJ40 ( XJ81 )
May 24, 2021 04:59 AM
bluechow
Jul 20, 2017 01:57 AM
jeffH
Jun 3, 2011 05:18 AM
chriscowan
Jan 1, 2010 10:32 AM
Tomcat
May 14, 2008 08:09 PM
