gas tank access question???
Old Jul 17, 2013 | 04:54 AM
asilverXJ8's Avatar
Default gas tank access question???
Tank has two straps holding it in, then almost looks like it would tilt down to change the fuel pump. Am I right? Or do you have to pivot the passenger side toward back of car because the filler neck won't allow it to "tilt"?
This is in a 2002 XJ8 where I have 10.5 volts DC on the two small gauge wires at the white connector at tank, so I assume pump is bad. Have no fuel pressure at valve on fuel rail.
Thanks for advice on getting to pump!
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
teacoff
Sep 10, 2015 08:25 AM
alpecsa
Sep 7, 2015 11:55 AM
