Guys with Manual Conversion/ Eliminating the TCM
Old Aug 23, 2012 | 10:37 PM
adam699's Avatar
Default Guys with Manual Conversion/ Eliminating the TCM
So, since I'm having a tough time getting anywhere with the TCM reprogramming for the Axle Ratio change, I'm starting to seriously consider going the standalone TCM route as they can be had for the same cost as some outfits claiming they can retune out TCM's. That way I can mess with all parameters on my own and to my liking.
My only problem is, how can we reprogram/fool the ECU to not miss the TCM?
I was thinking about messing with the linear switch to make the TCM think it's in neutral all the time but than wouldn't the rev limiter at 3000rpm be on all the time?
Old Aug 24, 2012 | 05:31 AM
JgaXkr's Avatar
You should just contact Phil @ Eurotek & get the TCM reprogrammed. Then you can fully enjoy your car.
Old Aug 24, 2012 | 07:38 AM
Sean B's Avatar
These guys have a box of tricks...
Home
Old Aug 24, 2012 | 05:14 PM
adam699's Avatar
Which eurotek is it? I googled and a few came out. Do you have a contact e-mail?
Thanks,
Adam
Old Aug 24, 2012 | 06:13 PM
JgaXkr's Avatar
:: Eurotek ::
Old Aug 28, 2012 | 04:43 PM
adam699's Avatar
So, since I'd really like to get the EGS52 into the car I picked up a 2010 722.6 from a Dodge Challanger. I'm going to tear it up to see how the valvebody looks like. Hopefully it's got the famous bluetops.
Old Aug 28, 2012 | 08:06 PM
JgaXkr's Avatar
Were the Blue Tops ever fitted to a Chrysler??? I thought they were Maybach only.
Old Aug 29, 2012 | 01:47 AM
adam699's Avatar
They were AMG. And I guess chrysler uses their own clutchpacks. No bluetop for chrysler.
Old Sep 7, 2012 | 08:15 PM
adam699's Avatar
Well, I finally touched base with Phil.... It's gotta be a hell of a tune as they quoted me $2450.00 for the TCM ratio change.
Old Sep 8, 2012 | 08:46 AM
JgaXkr's Avatar
I can only tell you that it does work. He has done at least 3 for me.
aholbro1
Dec 29, 2024 06:46 PM
ZJag
26
Sep 5, 2016 03:33 PM
Sambo21
Nov 19, 2015 03:55 PM
XJsc-guy
Sep 25, 2015 11:09 AM
jagent
Sep 7, 2015 05:00 PM
