hard to find gasket
Old Jan 21, 2017 | 04:47 PM
Bill Lauro's Avatar
Default hard to find gasket
1998 VDP on the end of each down pipe there is a flange with two bolts attached to a flex pipe to the cat. There is a two hole gasket at that point, anyone know were I can get two of them?
Bill
1998 XJ8 VDP
Old Jan 21, 2017 | 04:57 PM
avern1's Avatar
SNG barratt one of the forum sponsors lists them in their parts manual. Exhaust Gasket NNC6764AB 2. Send them an email and Don will get back to you right away.
Old Jul 7, 2017 | 04:39 PM
MrTeaser's Avatar
I need same gaskets for my 1999 XJR .. does anyone know the inside size of exhaust pipe at cats ?, a universal would work no? I can get universal shipped for $under 6 including shipping to my door, as soon as you mention Jaguar, it's $38 a piece with shipping to Canada is there a difference? someone filled mine with silicone when they replaced the hanger bearing last year.
Old Jul 7, 2017 | 05:50 PM
xjr2014_de's Avatar
Hi,
yes, an universal flex hose will do the job. I did replaced both sides a few weeks ago. Unfortunately I can't find the dimensions that I measured when I did the replacements.
But here's a picture off e*** with the dimensions of the universals that I used for my MY2000 XJR.
I used new gaskets as well but had to use additional sealing compound as the gaskets didn't manage to seal it properly.
I cut the exhaust right behind = downstram the flex hose, broke loose the bolts at the cat and flexed off the flex hose at the connecting piece to the cat.
After grinding down one side of the universal it fitted perfectly in the connecting piece. After cutting both ends to size each end slid easily into it's position, so I could weld it.
See attached pictures for condition before and after welding.
Attached Thumbnails hard to find gasket-uni_flex.jpg   hard to find gasket-img_20170506_143158.jpg   hard to find gasket-img_20170506_172105.jpg
Old Jul 7, 2017 | 08:39 PM
MrTeaser's Avatar
but what size was the gasket between your flex and the Cat ?
Old Jul 8, 2017 | 05:49 AM
xjr2014_de's Avatar
Then I didn't get your question.
Sorry, in that matter I can't tell you the dimensions. But in my case they turned out to be useless, since they didn't seal properly. So I guess it should work out without them and using exhaust sealing compound instead, if you don't get any reasonable universals.
Cheers, Alexander
Old Jul 8, 2017 | 06:14 AM
MrTeaser's Avatar
My thought was to use both, the exhaust sealing compound is leaking after about a year. Not something I want to have to repair yearly, but thanks for the advice.
Was hoping someone here might have known the size.
Old Jul 8, 2017 | 06:29 AM
xjr2014_de's Avatar
If it helps you I can take measurements of the flange and bolts as soon as I'm on a lift again. Should be within next week or so.
The diameter for fitting the flex hose in the flange is a little less than 48mm (that's why I had to grind down the D=48mm section of the flex pipe a little bit to slide on the flange). What I can do is take measurements of the total lenght and width of the flange = gasket and also of the distance between the bolts. Is that something that helps?
Old Jul 8, 2017 | 06:44 AM
Addicted2boost's Avatar
I'm quite sure it's 2" but no more that 2.25". I won't know for sure until I get to work on Monday though because I have a cat with that flange that I can measure the I.D. if you can wait that long.
Old Jul 8, 2017 | 06:56 AM
MrTeaser's Avatar
That be great Addicted, I was guessing it was around 2 to 2.25, I'll wait until I hear from you again.
Old Jul 10, 2017 | 08:51 AM
The cat to flexpipe hole I.D. Is 2" exactly.
The 2 outer mounting holes are 4" apart measuring the center of each hole. The mounting holes are 11 mm I.D.
Let me know if this is enough info.
Old Jul 10, 2017 | 11:12 AM
MrTeaser's Avatar
Thanks ..
Old Dec 3, 2017 | 05:49 PM
MrTeaser's Avatar
Default worked
Bought a pair of gaskets, off ebay for $2.31 shipped to the door, had to widen the bolt holes a 1/4" with die grinder, otherwise worked like a charm.
