harmonic balancer
Old Feb 12, 2015 | 09:24 PM
fredd60's Avatar
Default harmonic balancer
I am trying to replace the upper and lower chains and tensioners on a 1999 X308. Unable to remove the harmonic balancer. I have loosened the large centre nut, applied a puller, using the two bolt holes in the centre of the HB, belted the outer ring, no joy. Is there something I am missing, or a different procedure to use. Have searched the forums, but no more info found.
thanks
Pete
Old Feb 13, 2015 | 08:19 AM
motorcarman's Avatar
Here is the TSB for damper removal.
bob gauff
File Type: pdf
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
jonahjob
Oct 1, 2015 07:54 AM
AnD3rew
Sep 26, 2015 06:06 PM
Dicque
Sep 12, 2015 10:34 AM
