Help determining trim level
Old 06-20-2018, 09:04 AM
Brummel1's Avatar
Default Help determining trim level
Hi all. I have an 03 xj8, wondering if you can tell the trim level based on rims/chrome trim/interior etc... When I bought it on auction they called it a super v8, but it's not supercharged so I assume that's wrong.
Old 06-20-2018, 09:43 AM
Jhartz's Avatar
Looks like a base unit: XJ8. Looks like my first X308, which was a 2001 Canadian unit.
Not sure where you are located, but check for rust. Also Jaguars love vacuuming and any good leather cleaners . . .
Old 06-20-2018, 01:14 PM
avern1's Avatar
Received 1,318 Likes on 1,004 Posts
What are the badges on the back, a picture would help.
Old 06-20-2018, 04:36 PM
Brummel1's Avatar
Old 06-20-2018, 05:10 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
I do agree on the base model, charcoal grill inserts, no wood on the steering wheel, rims, etc., the white piping on the seats was maybe optional, maybe standard by 2003.
Seems they mis-routed the cooling hoses (thermostat and radiator -> expansion tank), pay some attention there as engine cooling is an important issue on these cars.
Looks you are in for quite a bit of work, welcome to the club!
Old 06-20-2018, 05:27 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
Another base vote.
Old 06-20-2018, 06:01 PM
avern1's Avatar
Right there with Base model.
Old 06-21-2018, 10:58 AM
Jhartz's Avatar
Should be able to find a new right tail light fixture on eBay. Stump hose looks like it is about to go (is that what you meant, Eric?).
Old 06-21-2018, 10:23 PM
omgimali's Avatar
No, the coolant lines from the reservoir are not guided properly. big problem
ericjansen (06-22-2018)
Old 06-22-2018, 10:08 AM
Jhartz's Avatar
I see what you mean: it looks like the hose going to the overflow needs to be disconnected and reconnected to the nipple going to the radiator and then extended to the radiator; the hose going to the radiator is actually the hose bent to go to the overflow bottle. As it sits now, the hose to the radiator is likely to burn through . . (that it?)
Old 06-22-2018, 05:59 PM
ericjansen's Avatar
The proper routing (minus the tag maybe ...)
I must say that I would like to see them going under the covers, those hoses are about the only distracting thing in the bay.
But considering the 'plastic-ness' of them, better not ...
Jhartz (06-23-2018)
Old 06-22-2018, 06:18 PM
Yeah mine snapped when doing the idler pulley we went with a proper sized hose & had no issues since.
jaguarcraver
XK120 XK140 XK150
03-30-2018 12:57 PM
mrbingha
12-26-2012 10:27 AM
magredvet
09-26-2012 04:24 AM
Spikepaga
08-18-2012 09:52 AM
deaddog
09-13-2011 03:02 PM
Quick Reply: Help determining trim level
