Help in finding 4.0 replacement motor
Old Jan 27, 2014 | 10:02 PM
tdfm046's Avatar
Default Help in finding 4.0 replacement motor
I am new to the forum,
I need to either find a replacement motor due to a broken timing chain or salvage my 99 VDP with only 72K miles. Any suggestions?
Old Jan 27, 2014 | 11:41 PM
sparkenzap's Avatar
Fleabay, or a local junk yard. Most breakers are on a network, so go to a large yard nearby. expect to bay between 2K to 3K.
Old Jan 31, 2014 | 03:12 PM
dsnyder586's Avatar
You have a minor chance that the chain broke and didn't bend any valves so repair would be VERY inexpensive- were you at speed when it broke or idling?
Old Feb 1, 2014 | 11:45 PM
tdfm046's Avatar
the chain broke during starting, right side after driving off and on all morning, not sure how much damage happened with the first mechanic who tried to start car.
Old Feb 2, 2014 | 05:28 AM
sparkenzap's Avatar
Its hard to diagnose an egne without starting the car!
Old Feb 4, 2014 | 10:00 AM
buckshaw's Avatar
For reference, here's one from my local Craigslist.
1999-2003 jaguar xk8 or xj8 motor complete.
Good luck!
Old Feb 5, 2014 | 05:16 PM
shawnethan's Avatar
I have one with 86K miles 2003 (updated tensioners) I will sell you for $2000 You can hear it run
Old Feb 6, 2014 | 09:09 AM
jaguar jon02's Avatar
Default 2000 model
got a 2000 with 100k on it for $2000 but you"ll have to take the whole car runs drives good. can come and drive it home, the chains are done, has good air, heat,tires.lost title jon@901 335-5137 in memphis tn
Old Feb 6, 2014 | 11:53 AM
tdfm046's Avatar
I plan to do the work next month, if you can wait a few weeks, I am interested. I understand there are 2 options depending on the VIN #. Can you provide to see if it is a match for mine?
Old Feb 6, 2014 | 12:31 PM
dsnyder586's Avatar
TDFM- the options are AJ26 or AJ27. The AJ26 (early 99) has VVT solenoids on the front timing cover, AJ27 has them sticking out the top of the camshaft covers so the easy way to tell is to look at the cam covers and see if you have wires plugged into something that goes into holes at the top front part of the cam covers (AJ27)or wires going to the front of the engine facing the radiator (AJ26).
xjrjag
Nov 27, 2025 09:16 AM
Robert1968
Jun 24, 2017 11:16 AM
David Mason
Sep 3, 2015 03:17 AM
casepie
Aug 30, 2015 09:49 PM
perfectphoto
Aug 29, 2015 10:11 PM
