Help with part identification (with valve cover gasket)
I need to replace valve cover gaskets (left and right) on my 2003 x308. However, I also noticed that it's leaking at two plugs, I'm looking for help identifying it.
Awesome, thank you guys! I'm greaful for your help. In that case, I have to just figure out if I need to order these separately or they come together with the valve cover gasket kit.
Is there a parts/service catalog that you guys maybe have available to download? It would be great to have a resource center in here with all files divided by model.
Yes, that kit from Rock Auto will service both valve cover gasket needs of your 2003 XJ8.
It includes the main valve cover gaskets, plus the eight rubber o-ring seals for the spark plug holes, plus the smaller rubber o-rings for each of the 28 securing bolts.
@Carnival Kid thank you. I also
ordered two solenoid seals you linked for me. Thanks!
Now I’m just trying to find out if LJA6195BG can be replaced with LJA6195BF. The only part catalog I found online is for 1998 XJ, not for 2003 (which has some parts different). However, I’m aware that would be a separate post.
