Hood won't open
Old Apr 23, 2008 | 10:19 AM
FactoryJaguarTech's Avatar
Default RE: Hood won't open
Remove the grill inserts and pull the cables.
Old Apr 23, 2008 | 12:33 PM
You should be able to access the cables through the grill. I am sorry...been a long time. You may want to wait for someone else to chime in too. Would hate to have wasted your time.
Old May 19, 2018 | 03:12 PM
Jonavences's Avatar
Mine won’t open from the driver side. So I’m stuck in the same scenario
Old May 19, 2018 | 04:30 PM
pdupler's Avatar
You actually have to remove the fender liners as your dealer has said and believe it or not, drill a hole for access, then stick a long screwdriver through the hole and actuate the latch. BTDT. There's at least a couple of threads on here about it with pictures showing exactly where to drill. Have to be careful as on the passenger side here in the US, you're drilling about a 1/2 inch from the positive battery cable. What typically happens is the cable end will pop out of the retainer on the latch.
Old May 19, 2018 | 07:37 PM
avern1's Avatar
It is a common problem. I have attached a link to a thread with pictures.
https://www.jaguarforums.com/forum/x...release-29427/
dsnyder586
Dec 29, 2024 07:39 PM
Dagny
Jun 11, 2024 01:06 PM
BadKat174
May 26, 2023 12:29 AM
Bc xj
Sep 17, 2015 06:34 PM
