How can I open THAT clip on the throttle body?
Old Dec 13, 2022 | 05:13 AM
Peter_of_Australia's Avatar
Default How can I open THAT clip on the throttle body?
It's night here now and before I continue the fight with that clip tomorrow, I thought I ask for help here.
After removing the timing chains, I am also in the process of removing the air intake...
X308 XJ8 1999 3.2L AJ27
But there is now a clip, which I cannot remove:
Circled in red: That clip fixes a T-piece (of a passing tube) to the lower throttle body.
I already pulled that plastic-clip, which is an integral part of the clip, which I can't get off.
And this is the top view of that mysterious clip design.
Does anyone know, how I can remove that clip so that I can finally take the air-intake out? Cheers.
Old Dec 13, 2022 | 05:21 AM
Addicted2boost's Avatar
Push up on that clip then pull the tee towards you.
Old Dec 13, 2022 | 05:25 AM
M. Stojanovic's Avatar
You don't remove that U clip, you push it further in which will release the Tee from the adapter on the intake elbow and you can then pull/wiggle the Tee out.
Did you mean like that? :
So push that clip INTO the clip and then pull?
Old Dec 13, 2022 | 08:21 AM
Yes, push in the direction of the arrow, hold it pushed if it tries to spring back, and disconnect the "Tee" from the inlet elbow.
Old Dec 13, 2022 | 09:07 AM
RandyS's Avatar
...a novel little connector...one you don't see everyday.
Old Dec 13, 2022 | 11:30 AM
Quadcammer's Avatar
I find that plastic release "U" to be a pain. Two very small flat head screwdrivers inserted into the slots on the connector work every time for me with no damage and less pressure.
Old Dec 13, 2022 | 06:13 PM
Thanks, ADDICTED and M.
I did it. I actually tried the same thing already yesterday, but it requires first a huge conviction that that is the MO to wiggle it off, otherwise you would not wiggle enough, and you that's it then.
Also: Placing such a connection-system into such an utterly inaccessible location was another gaffe by Jag.
So the way to get that clip off is exactly as I did it: First I had to remove the complete fuel-rail-system (to get that out of the way), then I had to tell the air-intake "Roll over!" (like to a dog), and only then I can do as above.
Old Dec 14, 2022 | 02:26 AM
earny's Avatar
By the way, if not already known: the U-shaped clip shown in the picture is the official tool from Jaguar to loosen for example the part load breather hose etc. ;-)
Old Dec 14, 2022 | 03:17 AM
Moin, Bernd! Gruesse nach Koeln. Habe da auch ein paar Jahre gewohnt und gearbeitet (Ford natuerlich, und dann Jaguar in Coventry um am X400 zu designen - dorthin geschickt von einer Firma in Koeln.)
Old Dec 14, 2022 | 06:12 AM
earny's Avatar
Hi Peter, here is winter now and some snow, you are sitting in the sun, aren`t you?;-) Today I wanted to work a little bit on my newly acquired XJR at my garage, but temperatures are below zero. Best greetings!
Old Dec 14, 2022 | 06:20 AM
Nice green on the XJR. Most of my Jags are green. Yes, the temperature here are pretty much ideal all year round to fiddle around on Jags. We have a very "cold" summer currently - about 25°C, where it is normally above 30. When you start working on a Jag, normally you always find more things to fix than anticipated. If you need ideas: An ATF full flush is probably due... - and you should stick to the recommended ATF.
schoeman
Nov 4, 2022 05:23 AM
Aj Leduc
May 27, 2021 04:09 PM
JaguarXKR
Jun 2, 2020 09:29 PM
SD96XJ6L
Jan 11, 2016 01:14 PM
Roadhogg
Jun 27, 2012 05:38 PM
