How do I get to O2 sensor...
Old Mar 21, 2010 | 09:29 PM
Crosbo's Avatar
Default How do I get to O2 sensor...
...on the driver's side. I've purchased the new upstream sensor and I've been lucky enough to get the sensor tool on the sensor, but there is no way I can get the ratchet on the tool, much less get my arm up in there (from the bottom) far enough to get the job done...and I can't get to it from the top either.
Anybody done this on the XJ8...how'd you do it?
Old Mar 24, 2010 | 12:47 PM
Dan R's Avatar
Take a look at the thread,
V8 O2 sensor changing tips? and the technique described by Icebreaker.
I used a 22 mm crows foot to remove the sensor though a short collar 02 socket SP tools 88750 may have done the job. Found it in the toolbox afterwards! I got it from the Volvo IPD site.
Not difficult, but time consuming.
Old Mar 24, 2010 | 03:42 PM
QuadManiac's Avatar
Heres the link:
https://www.jaguarforums.com/forum/s...+changing+tips
Old Mar 24, 2010 | 03:43 PM
Crosbo's Avatar
Ah yes, I see it now. Thanx for pointing that out to me Dan.
I could see that I wanted to remove the heat shield, but I was trying to do so without moving the coolant tank. I guess now I will go back (when it stops raining) at it with a new attitude and determination...and a better plan.
Thanx again Dan.
Old Mar 24, 2010 | 05:18 PM
Crosbo's Avatar
Thanx to you as well Quad.
Old Mar 25, 2010 | 09:01 PM
kenncl's Avatar
Are you sure you need a new O2 sensor. My bad O2 sensor code turned out to be a MAFS that needed cleaning. I must say it is a VERY tight spot to get to the O2 sensor.
Good luck.
CaneCounsel007
Sep 3, 2015 07:33 PM
Striker27
Jul 5, 2015 09:24 PM
tony bosco
May 24, 2014 02:09 PM
pimpjag
Feb 23, 2014 11:08 AM
JaggyZ639
Dec 19, 2013 08:26 AM
