How many refill for zf transmission?
Old Dec 30, 2019 | 02:05 PM
RA110623's Avatar
Banned
Default How many refill for zf transmission?
Hi guys just want to know ist okay to fill the transmission twice without 2k miles? Im changing it because i had leaking in the transmission cooler And water's mixed with transmission fluid little bit so today just drained 3 liters today and refilled it with another 3 liters . The oil that came out was black and had bad smell . How many times i must drain and refill this transmission?
​​​​​​Thanks.
Old Dec 30, 2019 | 04:02 PM
RJ237's Avatar
I think you need to have it flushed by a transmission shop or dealer. The torque converter contains a lot of the fluid and it would not be possible to get all of the water out of the system by doing multiple drain/fills.
Old Dec 30, 2019 | 05:47 PM
Highhorse's Avatar
+1 to RJ's suggestion ...you need to get all the water out or you'll nuke your unit....this is true for any automatic trans. H2O and transmissions are a death sentence combo. If your fluid is black after just changing it, your burning up your clutches it sounds like.
Old Jan 5, 2020 | 01:30 PM
RA110623's Avatar
Banned
Pulled about 3 liters from transmission lines but unfortunately the fluid was black
joeleerj
Sep 14, 2016 09:40 AM
DandyAndy
May 29, 2016 12:18 PM
devxiav
Mar 3, 2015 05:54 PM
Redeye
Oct 15, 2014 03:42 PM
AlbBolivar
Nov 23, 2013 11:44 PM
