How much fluid is enough and what kind?
Old Apr 12, 2013 | 07:37 PM
coastaljag98's Avatar
Default How much fluid is enough and what kind?
Trying to get things ready to change my tranny fluid. I've read several posts but want to make sure. I have seen its a 6mm hex for the fill plug. I'm guessing I need a hand pump?? How do I know when the level is right? Is it like checking a rear differential?
Old Apr 12, 2013 | 08:11 PM
Vector's Avatar
I guess you have an XJ8 since you posted in this section, but knowing your year and model for sure will help get you the correct answers. The NA and SC cars have different trannys.
Try putting your model and year in your signature or edit your original post and add that info.
Vector
Old Apr 12, 2013 | 09:09 PM
I'm using mobile so maybe that's why but its a 99 xj8 VDP
Old Apr 13, 2013 | 04:36 AM
Highway Star's Avatar
This sheet, taken from the Jaguar XJ8 Technical Specifications document, might help.
Transmission and Differential Fluids.pdf
Old Apr 13, 2013 | 04:39 AM
test point's Avatar
Without draining your torque converter, which you cannot do, it will take a little over 5 qts. With the car level on jack stands or a lift. Fill until ATF drains out the fill hole at about 120 degrees F. That temp is about where it becomes uncomfortable to hold your hand on the bottom of the transmission pan. Move the shift lever slowly through the positions several times with the engine running.
I hope that you haven't fallen for the 'only use Pentosin' mantra. Ford now has formally stated that MERC V meets the LT71141 specification as has several other brands.
All the links you could ever want: https://www.jaguarforums.com/forum/x...uestion-78968/
And here's one from the JIT:
Transmission Fluid Drain and Refill 44.24.02.pdf
Old Apr 13, 2013 | 06:35 PM
Thanks guys!
Old Apr 13, 2013 | 09:49 PM
Anyone know of where to get this Mercon V??? I have not see it at Walmart. Just IV
Old Apr 13, 2013 | 11:28 PM
Or what fluid can we use?
Old Apr 14, 2013 | 01:36 AM
Basically any fluid that complies with the LT 71141 specs (see fluids sheet again). If you find such declaration on the fluid's bin it's one you can use. Given that you have faith in the quality standards of the manufacturer.
Old Apr 14, 2013 | 07:12 AM
test point's Avatar
MERCON V should be available almost anywhere ATF is sold. Certainly any auto parts stores.
Old Apr 14, 2013 | 08:36 AM
Thanks. All my other cars weren't this picky lol
Old Apr 14, 2013 | 05:45 PM
jaguar jon02's Avatar
i got qts of BILSTEIN for my 99 xjr from roy rogers forgien auto parts for 15.00 a qt. as the bottle is in german ,i don't know what it says. as the zf is german i guess this is what it takes
Old Apr 14, 2013 | 07:18 PM
test point's Avatar
The XJR has a Mercedes transmission, the XJ8 has a ZF. Totally different fluids.
Old Apr 14, 2013 | 08:19 PM
Ima go with the Mercon V and do filter and fluid. Mine has 106k and I bet previous owner didnt do it.
Poet
Feb 7, 2025 02:18 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Stilling
Oct 5, 2015 04:23 PM
Poet
Oct 2, 2015 09:00 AM
Rocky15
Sep 28, 2015 04:59 PM
