Ignition and glove box lock cylinder removal
Old Jan 4, 2015 | 10:32 AM
ixj8it's Avatar
Default Ignition and glove box lock cylinder removal
I am in the process of getting more of my xj8 parts laying around ready to sell. I want to sell the key and all lock cylinders as a set. I have a problem of not readily seeing how to remove the lock cylinder from the steering column. I have the same question about the glove box. Any help would be appreciated! Thanks in advance
Old Jan 4, 2015 | 04:10 PM
clyons's Avatar
This is from the 2003 XK series shop manual. I doubt the XJ is too different.
https://www.jaguarforums.com/forum/a...ition_lock.pdf
Old Jan 4, 2015 | 08:07 PM
jimlombardi's Avatar
Here are instructions & illustrations from JTIS software - XJ X308 Glove Compartment Lid Handle & Lock R&I:
Glove Box Lid R&I:
Glove Box R&I (not sure if you need to remove the Glove Box):
Jim Lombardi
Old Jan 5, 2015 | 07:20 AM
ixj8it's Avatar
Thanks for the information! I was concerned about breaking the glovebox! Now if I only knew how to remove the ignition lock cylinder from the steering column! Alldata doesnt have any of this stuff, unfortunately
Old Jan 5, 2015 | 09:38 AM
Look at this JPEG estracted from JTIS on steering column lower shroud removal:
After you lower the the cowl - see if the lock cylinder can be removed using the information provided by member cylons:
I put it into another JPEG file - Image inserted below:
Jim Lombardi
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jagent
Sep 12, 2015 01:40 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
