inside door lights
Old Jan 18, 2008 | 06:22 PM
FactoryJaguarTech's Avatar
Default RE: inside door lights
Fuse 13 and 15 in Left hand heel board box.
Fuse 15 in right hand heel board fuse box.
I would start though by disconnecting battery for a few minutes then reconnect and check lamp operation.
The fuses are assuming you have left hand drive car and we talking about the puddle lamps (the ones in the door).
Let us know...and we will go to the next step.
Old Jan 19, 2008 | 04:52 PM
when you sit in vehicle, engine running, all doors, hood and trunk closed, what shows on instrument pack?
Next open then close all doors one at a time and monitor cluster again. Any messages come up?
Old Jan 22, 2008 | 07:15 PM
If only the rear door say Door Ajar then I would suspect that there is a problem with the other 3 door latches. They really have nothing in common though. Did you just buy car?
The door ajar switches are built into the door latches. Not sure about pricing at all. Maybe you can get with Ken@britishparts.com to see if he has latches.
I am pretty convinced that is what it is, but start with one and if it corrects that one part of the problem get the other two. Not common for them all to go at once, but not unheard of.
Also just to edit. Today I had a vehicle that was doing the same thing, only rear door wouldnt trigger but the rest would. I replaced the faulty latch in the rear door, but the old latch seems to have shorted the rear door module. So although the latch now works, there is now the need to replace the module. I don't forsee that happening to you as it is not common. But fingers crossed eh.
99xk8guy
Sep 29, 2025 10:51 PM
VinnyT
72
Sep 28, 2025 12:17 PM
GordoCatCar
Jan 2, 2017 01:10 PM
bdboyle
Sep 4, 2015 06:16 AM
innzane
Sep 2, 2015 10:08 AM
