Intermittant fault at start up
Old Sep 16, 2014 | 02:21 PM
GaineR's Avatar
Unhappy Intermittant fault at start up
I have a 2001 XJ 4.0 V8. I has an intermittent start up issue, which is strange and annoying
The dash board information panel reads in sequence
1. Trax on available
2. ASC not available
3. Gearbox failure
4. Engine in failsafe mode
The ignition key cannot turn and the gear lever is locked into park and the car will not start! It eventually will start, perhaps over an hour later.
I have had the ABS booster pump replaced, have had all of the ABS sensors tested, their earths and wiring checked, the gear lever micro switch is perfect and I have replaced the battery. Nothing is showing up on the diagnostics. My local Jaguar dealer is as baffled as I am.
What can it be?
Old Sep 16, 2014 | 02:40 PM
Welcome to the forum GaineR,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Sep 16, 2014 | 02:45 PM
JimmyL's Avatar
I would start cleaning and checking power points and ground (earth) points. Don't trust the crimps on the ground straps either. Many posts in the archives on these little buggers.
Old Sep 16, 2014 | 03:04 PM
GaineR's Avatar
It sounds like you've had similar problems. Which ground points did you find the most troublesome?
Old Sep 18, 2014 | 06:48 AM
JimmyL's Avatar
I had a problem with the main ground strap at the battery. Called the wife to come and give me a jump, and when I just fiddled with the ground strap the car started. It was also very hot. Turns out the connection at the crimp was not good (although the ends were fine). I think I added solder at first, but eventually replaced it.
Old Sep 19, 2014 | 01:51 AM
GaineR's Avatar
Jim
Thanks! I'll check it out this Saturday. It's annoying but otherwise my Jag is running great.
Robbie
Old Sep 19, 2014 | 05:37 AM
avt007's Avatar
Check out the electrical link in my signature, it may help.
Old Sep 20, 2014 | 08:54 AM
GaineR's Avatar
Rob
Many thanks! Page 22 details my symptoms exactly. I'll get on to it and check out the Inertia switch.
Robbie
Old Oct 5, 2014 | 03:18 PM
GaineR's Avatar
Originally Posted by GaineR
Rob
Robbie
To AVT007: Thanks I've installed a new inertia switch, new engine earth strap and a new battery earth strap. So far so good' Very good electrical fault guide that you produced! Thanks!
JarodL
Mar 7, 2024 01:39 AM
cissdm
May 3, 2016 06:02 AM
Bones
Sep 8, 2015 08:34 PM
XJsc-guy
Sep 2, 2015 11:43 AM
